I'm working on a little program that will render multiple camera views within a drawing without any user interaction. However, my renderings are looking a lilttle less than perfect. For instance, in a room with walls, doors, steel, floor and ceiling slabs and mechanical equipment the only thing I end up with are the slabs and the steel. If I do the rendering the old fashioned way, I get everything (as I should). Below is the code... Am I missing anything??
Comments & suggestions are welcome!
;;; File Name ............ RENDERFARM.lsp
;;; Main Function ........ RENDERFARM
;;; Written By ........... Matt W
;;; Compatibility ........ AutoCAD 2005
;;; Notes:
;;; Menu entry = ^P^C^C(load "RENDERFARM");RENDERFARM;
;;; Revision History:
;;; Version ..... 1.0 10-14-06 Initial Release
;;; Function: RenderFarm
;;; Description: Batch renders a drawing with AEC_CAMERAs
(defun C:RenderFarm ( / a len cnt ent obj)
(setq a (ssget "x" '((0 . "AEC_CAMERA"))))
(arxload "acrender.arx")
(setq len (sslength a))
(setq cnt 0)
(repeat len
(setq ent (ssname a cnt))
(setq obj (entget (ssname a 0)))
(if (= len 1)
(command "aeccamera" "view" "")
(c:rpref "dest" "file")
(c:rfileopt "tiff" 2048 1366 1.0 "C24")
(c:rpref "stype" "aray")
(c:rpref "toggle" "cache" "on")
(c:rpref "toggle" "shadow" "on")
(c:rpref "toggle" "finish" "on")
(c:rpref "toggle" "skiprdlg" "on")
(c:render (strcat "E:/Temp/RenderFarm-" (rtos cnt 2 0) ".tif"))
(command "aeccamera" "view" ent "")
(setq cnt (+ cnt 1))
(alert "RENDERFARM is complete!")
