Author Topic: Segment Labels Format  (Read 9465 times)
  • Custom Title
« on: May 05, 2011, 09:25:56 AM »
I'm trying to use segment labels ('cause they're getting better every version it seems) again in my daily work. I do mostly boundary work. My label problem is the distance, I _need_ to have it after the bearing in all cases. If my lines are east-west its not a problem but north-south is. The distance is always in front of the bearing. Hope that makes sense! I can't seem to figure out the settings for switching them, assuming there is, of course!
thanks! :)
Re: Segment Labels Format
« Reply #1 on: May 05, 2011, 09:28:48 AM »
you are going to need two styles, or one good one.
set up the components in the label so that the distance is AFTER the Bearing...then it will behave
so a style like Bearing and Distance Above.. will always show the distance after the bearing.
OR send me a sample of your file to examine the 'bad' results.
this seems to work for me:
<[General Segment Direction(Udeg|FDMSdSp|MB|P4|RN|DSn|CU|AP|EN|DZY|OF)]><[General Segment Length(Uft|P3|RN|AP|GC|UN|Sn|OF)]>'
« Last Edit: May 05, 2011, 09:41:13 AM by Higgs Boson's Mate »
alanjt
  • Standby for witty remark...
« Reply #2 on: May 05, 2011, 09:45:15 AM »
I've never seen it swap the position of the bearing and label.
eg.
<[General Segment Direction(Udeg|FDMSd|MB|P4|RN|DSns|CU|AP|EN|DZN|OF)]>  <[General Segment Length(Uft|P2|RN|AP|Sn|OF)]>'
I'm sure it's basically the same as Michael's.
Dropbox
  • Custom Title
« Reply #3 on: May 05, 2011, 09:53:46 AM »
DUH ... now I see what ya mean. I was trying to do something else.
thank ya much.
« Reply #4 on: May 05, 2011, 09:54:47 AM »
thank ya much.
well don't do that
OK?
alanjt
« Reply #5 on: May 05, 2011, 09:56:21 AM »
thank ya much.
Individuality is overrated. Joins us Mark.
Dropbox
« Reply #6 on: May 05, 2011, 09:59:04 AM »
eg.
OH no...
Your formatting is so much more lifelike than mine.
And your use of code tags, makes me look like an amateur poster.    ;-)
alanjt
« Reply #7 on: May 05, 2011, 10:02:02 AM »
eg.
OH no...
Well, I try.
Dropbox
alanjt
« Reply #8 on: May 05, 2011, 10:03:23 AM »
Truth be told, I wish I knew a fraction of what you know about C3D.
Dropbox
  • Custom Title
« Reply #9 on: May 05, 2011, 11:39:27 AM »
so how do you guys handle the plat (P) dimensions in your labels? Or do you!
wbonnet
« Reply #10 on: May 05, 2011, 11:39:53 AM »
It's friggin unbelievable what Michael Farrell can do with Civil 3D.  Thanks for all the help Mike, it's been greatly appreciated.
alanjt
« Reply #11 on: May 05, 2011, 12:02:29 PM »
I just have a secondary style with the (P) suffix, but I'd love to know what Michael does.
Dropbox
« Reply #12 on: May 05, 2011, 12:06:11 PM »
as in being able to show record, and or measured, or?
exacttly what formatting are these  Plat-tesque labels needing to be in?
  • Custom Title
« Reply #13 on: May 05, 2011, 01:25:04 PM »
Yes. We are required to show; A comparison between recorded directions and distances with field measured directions and distances.
  • Custom Title
« Reply #14 on: May 05, 2011, 01:26:38 PM »
I thought about that too but then you'd have to have all kinds of lines in your dwg. So far the best solution I can come up with is just editing the label and adding 100'(P).
