Author Topic: Distance from point to line (without vlax)  (Read 2901 times)
AcoCar
  • Mosquito
« on: September 28, 2021, 02:20:50 PM »
I am relatively new AutoLISP user, and i need some help to make routine for finding closest (perpendicular) distance from point to line, i know its easy with "vlax-curve-getClosestPointTo" command i did it that way, but i need to go around that, and make code without using 'vlax' functions, because to my knowledge MicrosurveyCAD 2014 doesn's support it (maybe i'm wrong, I will be glad if someone corrects me about this) but i tried using routine that I made, works perfectly with AutoCad and Brics....but it fails with MScad.
If someone could give me an idea how to work around this, i will be very grateful. :)
Re: Distance from point to line (without vlax)
« Reply #1 on: September 28, 2021, 03:49:02 PM »
If it's a line use the INTERS function combined with POLAR.
d2010
« Reply #2 on: September 28, 2021, 03:58:33 PM »
Can the MicrosurveyCAD-2014, execute programs AutoLisp.R14 as .lsp?
AcoCar
  • Mosquito
« Reply #3 on: September 28, 2021, 05:18:46 PM »
Thank you very much, works perfectly :D
« Reply #4 on: September 28, 2021, 06:13:37 PM »
Glad to to help .. be aware that this only performs similar to getclosestpointto if the pick point is within the start and end points perpendicularly.
  1. (defun _cptl (e p / p1 p2 p3)
  2.   (if (and e p)
  3.     (progn (setq p1 (cdr (assoc 10 (entget e)))
  4.                  p2 (cdr (assoc 11 (entget e)))
  5.                  p3 (inters p (polar p (+ (angle p1 p2) (/ pi 2)) 1e-8) p1 p2 nil)
  6.            )
  7.            (grdraw p p3 3)
  8.     )
  9.   )
  10.   p3
  11. )
  12. (_cptl (car (entsel)) (getpoint))
« Last Edit: September 28, 2021, 10:57:25 PM by ronjonp »
« Reply #5 on: September 28, 2021, 06:15:21 PM »
You could alternatively use my Project Point to Line function, and then use the standard AutoLISP distance function to calculate the distance between the original point and the projected point.
« Reply #6 on: September 28, 2021, 06:21:14 PM »
Very cool Lee  8-)
« Reply #7 on: September 28, 2021, 07:23:11 PM »
Cheers Ron :-)
gile
  • Marseille, France
« Reply #8 on: September 29, 2021, 02:14:59 AM »
Another way using vector calculus.
  1. ;; Returns the length of a vector
  2. (defun gc:VecLength (v) (distance '(0. 0. 0.) v))
  3.
  4. ;; Returns the cross product of two vectors
  5. (defun gc:CrossProduct (v1 v2)
  6.   (list (- (* (cadr v1) (caddr v2)) (* (caddr v1) (cadr v2)))
  7.         (- (* (caddr v1) (car v2)) (* (car v1) (caddr v2)))
  8.         (- (* (car v1) (cadr v2)) (* (cadr v1) (car v2)))
  9.   )
  10. )
  11.
  12. (defun distancePtLine (pt p1 p2 / v)
  13.   (setq v (mapcar '- p2 p1))
  14.   (/ (gc:VecLength (gc:CrossProduct v (mapcar '- pt p1)))
  15.      (gc:VecLength v)
  16.   )
  17. )
AcoCar
  • Mosquito
« Reply #9 on: September 29, 2021, 05:51:53 PM »
This looks very nice, i had specific problem in mind, input was x number of points where first two represent axis, and i need to measure closest distance of every other point to that axis. I solved it using combination of Inters and Polar functions, as Ron suggested, it seems almost funny now, but i have spent few days trying to figure it out. Thank you once again!
VovKa
  • Ukraine
« Reply #10 on: September 30, 2021, 05:40:57 AM »
one more to the colleciton
(defun vk_GetPerpenLength (p1 p2 P / A B C)
  (setq A (distance p1 P)
B (distance p2 P)
C (distance p1 p2)
  (sqrt (abs (- (expt A 2) (expt (/ (+ (- (expt A 2) (expt B 2)) (expt C 2)) (* 2 C)) 2))))
« Reply #11 on: September 30, 2021, 04:33:28 PM »
Nice use of Heron's formula VovKa  :-)
VovKa
  • Ukraine
« Reply #12 on: September 30, 2021, 05:55:59 PM »
oh man, i thought i've invented it myself :(
joking
remember it from my geometry class back at school :)
« Reply #13 on: September 30, 2021, 06:12:25 PM »
I'd have believed you :wink:
apricot125
  • Mosquito
« Reply #14 on: November 04, 2021, 09:19:18 PM »
Helen formula
(defun ClosedDis( / pt0 pt1 pt2 s disa disb disc ename edata area ans ang pt disx osmd)
  (setq osmd (getvar "osmode"))
  (setvar "osmode" 0)
  (Setq pt0 (getpoint "Select the point out of the line: ")
        ename (car (entsel "Select the line: "))
        edata (entget ename)
        pt1   (cdr (assoc 10 edata))
        pt2   (cdr (assoc 11 edata))
        disa  (distance pt1 pt2)
        disb  (distance pt0 pt1)
        disc  (distance pt0 pt2)
        s     (/ (+ disa disb disc) 2.0)
        area  (sqrt (* s (- s disa) (- s disb) (- s disc)))
        ans   (/ (* 2.0 area) disa)
        ang   (angle pt1 pt2)
        disx  (sqrt (- (* disb disb) (* ans ans)))
        pt    (polar pt1 ang disx)
  ;(command "_line" pt0 pt "")
  (entmake (list '(0 . "LINE") (cons 10 pt0) (cons 11 pt) '(62 . 1)))
  (setvar "osmode" osmd)
« Last Edit: November 04, 2021, 10:00:04 PM by apricot125 »
