Author Topic: setting to ZERO the ZETA of VERTEXES . . .  (Read 1394 times)
domenicomaria
« on: May 31, 2021, 04:43:14 AM »
  1. (defun C:LINE,PLINE>ZETA-ZERO ( / i ind n-rep new-el p10 p11 ss x-el x-en x-et x-pt)
  2.    (setq ss (LM:SSGET "\nselect LINEs and POLYLINEs to SET VERTEXES to ZETA=0 : " '(((0 . "LINE,LWPOLYLINE"))) ) )
  3.    (setq n-rep (sslength ss) ind 0)
  4.    (repeat n-rep
  5.       (setq x-en   (ssname ss ind )
  6.             x-el   (entget x-en   )
  7.             x-et   (:DXF 0 x-el   )
  8.       )
  9.       (cond
  10.          (   (= x-et "LINE")
  11.              (setq p10 (:DXF 10 x-el)   p11 (:DXF 11 x-el)
  12.                     x-el (subst (cons 10 (list (car p10) (cadr p10) 0.0) ) (cons 10 p10)  x-el)
  13.                     x-el (subst (cons 11 (list (car p11) (cadr p11) 0.0) ) (cons 11 p11)  x-el)
  14.              )
  15.              (entmod x-el)
  16.          )
  17.          (   (= x-et "LWPOLYLINE")
  18.              (setq  new-el
  19.                    (mapcar '(lambda (i)
  20.                               (if (and (= (car i) 10) (setq x-pt (cdr i)))
  21.                                  (cons 10 (list (car x-pt) (cadr x-pt) 0.0))
  22.                                  i
  23.                               )
  24.                            )
  25.                           x-el
  26.                   )
  27.              )
  28.              (entmod new-el) (entupd x-en)
  29.              ;   (setq new-el-s new-el)
  30.          )
  31.       )
  32.       (setq ind (+ 1 ind) )
  33.    )
  34. )
Why with LWPOLYLINE it doesn't work ?
domenicomaria
Re: setting to ZERO the ZETA of VERTEXES . . .
« Reply #1 on: May 31, 2021, 05:00:01 AM »
ok
I need to change the elevation too !
38 !
And if the LWPOLYLINE is 3D-rotated and its UCS is not WCS ?
what to do to project it in the XY plane?
TRANS ? i suppose !  :idiot2:
ribarm
  • Marko Ribar, architect
« Reply #2 on: May 31, 2021, 06:56:26 AM »
Untested, you are missing sub functions (LM:ssget) and (:DXF)...
  1. (defun C:LINE,PLINE>ZETA-ZERO ( / i ind n-rep new-el p10 p11 ss x-el x-en x-et x-pt )
  4.   (repeat n-rep
  8.      )
  9.      (cond
  14.             )
  15.             (entmod x-el)
  16.         )
  18.             (setq new-el
  21.                                 (cons 10 (trans x-pt x-en 1))
  22.                                 i
  23.                              )
  24.                           )
  25.                          x-el
  26.                  )
  27.             )
  28.             (setq new-el (subst (cons 210 (trans '(0.0 0.0 1.0) 1 0 t)) (assoc 210 new-el) new-el))
  29.             (setq new-el (subst (cons 38 0.0) (assoc 38 new-el) new-el))
  30.             (entmod new-el) (entupd x-en)
  31.         )
  32.      )
  33.      (setq ind (+ 1 ind) )
  34.   )
  35. )
  36.
M.R. on Youtube
domenicomaria
« Reply #3 on: May 31, 2021, 08:04:13 AM »
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
(defun :DXF (code elist) (cdr (assoc code elist)))
domenicomaria
« Reply #4 on: May 31, 2021, 08:09:25 AM »
  2.    ;   (:UNDO-GROUP-BEGIN)
  3.    (setq ss (LM:ssget "\nselect LINEs and POLYLINEs to SET VERTEXES to ZETA=0 : " '(((0 . "LINE,LWPOLYLINE"))) ) )
  4.    (setq n-rep (sslength ss) ind 0)
  5.    (repeat n-rep
  6.       (setq x-en    (ssname ss ind )
  7.             x-el   (entget x-en   )
  8.             x-et   (:DXF 0 x-el   )
  9.       )
  10.       (cond
  11.          (   (= x-et "LINE")
  12.              (setq p10 (:DXF 10 x-el)   p11 (:DXF 11 x-el)
  13.                     x-el (subst (cons 10 (list (car p10) (cadr p10) 0.0) ) (cons 10 p10)  x-el)
  14.                     x-el (subst (cons 11 (list (car p11) (cadr p11) 0.0) ) (cons 11 p11)  x-el)
  15.              )
  16.              (entmod x-el)
  17.          )
  18.
  19.          (   (= x-et "LWPOLYLINE")
  20.              (setq  new-el
  21.                   (mapcar '(lambda (i)
  22.                               (cond
  23.                                  (   (and (= (car i) 10) (setq x-pt (cdr i) ) )
  24.                                     (cons 10 (list (car x-pt) (cadr x-pt) 0.0))
  25.                                  )
  26.                                  (   (and (= (car i) 38) (/= (cdr i) 0.0))
  27.                                     (cons 38 0.0)
  28.                                  )
  29.                                  (t i)
  30.                               )
  31.                            )
  32.                            x-el
  33.                   )
  34.              )
  35.              (entmod new-el)   (entupd x-en)
  36.              ;   (setq new-el-s new-el)
  37.          )
  38.       )
  39.       (setq ind (+ 1 ind) )
  40.    )
  41.    ;   (:UNDO-GROUP-END)
  42.    ind
  43. )
this is the working code . . .
but i want understand
if the LWPOLYLINE is 3D-rotated and its CS is not parallel to WCS
what to do to project it to get its projection in the XY plane . . .
I suppose I have to study some Lee Mac code  . . .
« Last Edit: May 31, 2021, 08:18:01 AM by domenicomaria »
domenicomaria
« Reply #5 on: June 01, 2021, 03:51:59 AM »
i am trying to project a (3d rotated) lwpolyline in the XY plane.
The following code, works.
It modifies the lwpolyline and the result is the projection of it, in the XY plane
but the good result, is TRANSLATED along the Y axis !
And I am not able to understand why this happens !
I probably omit a displacement . . .
When I use TRANS ?
  1. (defun :DXF (code elist) (cdr (assoc code elist)))
  2. (defun C:LWP>XY ( / i new-el x-210 x-el x-en x-pt )
  3.    (setq x-en  (car (entsel "\nselect a LWPOLYLINE to project into XY plane : "))
  4.          x-el  (entget   x-en )
  5.          x-210 (:DXF 210 x-el )
  6.    )
  7.
  8.    (setq  new-el
  10.                      (cond
  11.                         (   (and (= (car i) 10) (setq x-pt (trans (cdr i) x-210 0) ) )
  12.                             (cons 10 (list (car x-pt) (cadr x-pt) ) )
  13.                         )
  14.                         (   (= (car i) 38)  (cons 38 0.0)   )
  15.                         (   (= (car i) 210) (cons 210 '(0 0 1) )   )
  16.                         (t i)
  17.                      )
  18.                   )
  19.                   x-el
  20.          )
  21.    )
  22.    (entmod new-el)
  23.    (entupd x-en)
  24.    (setq new-el-s new-el)
  25. )
« Last Edit: June 01, 2021, 03:55:40 AM by domenicomaria »
roy_043
  • BricsCAD 18
« Reply #6 on: June 01, 2021, 09:06:56 AM »
you need to translate the points as 3D points. IOW you need to add the elevation to the 2D GC 10 points, translate, and then remove the Z.
domenicomaria
« Reply #7 on: June 01, 2021, 01:11:23 PM »
  2. (defun :PT-3D>2D (ptx) (list (car ptx)(cadr ptx)))
  3. (defun :PT-SET-Z (ptx z) (list (car ptx)(cadr ptx) z) )
  4.
  5. (defun C:LWP>XY ( / i new-el x-38 x-el x-en x-pt )
  6.
  7.    (setq x-en  (car (entsel "\nselect POLYLINEs to project into XY plane : "))
  8.          x-el  (entget   x-en )
  9.          x-38  (:DXF 38  x-el )
  10.    )
  11.
  12.    (setq  new-el
  13.          (mapcar '(lambda (i)
  14.                      (cond
  15.                         (   (and (= (car i) 10)
  16.                                 (setq x-pt (:PT-SET-Z (cdr i) x-38) )
  17.                                 (setq x-pt (trans x-pt x-en 0 t) )
  18.                             )
  19.                             (cons 10 (:PT-3D>2D x-pt) )
  20.                         )
  21.                         (   (= (car i) 38)  (cons 38 0.0)   )
  22.                         (   (= (car i) 210) (cons 210 '(0 0 1) )   )
  23.                         (t i)
  24.                      )
  25.                   )
  26.                   x-el
  27.          )
  28.    )
  29.    (entmod new-el)
  30.    (entupd x-en)
  31. )
  32.
  33.
  34. (defun c:k () (C:LWP>XY) )
roy_043
thank you.
It works well, now .
But I have still to understand well, why it works . . .
ciao
domenicomaria
« Reply #8 on: June 03, 2021, 01:32:18 AM »
however, I found this SUPERFLATTEN, which is "slightly"  :? :lol: better. . .
http://www.theswamp.org/index.php?topic=18153.0
