Is anyone editing the column after it is created since the source is an excel file? If not, does the justification really matter? If it does, express tools has a command to change justification without moving text, TJUST
Sometimes yes, sometimes No,
This is a constant problem for me.. as the project is supposed to be directed from the log, not the index.
At times, the engineer will take a short cut and update the index, and not the log, or the drawing sheets. Or, he/she will update the log and not tell any CAD technician. This is why I want to generate the script. Per our client the Project log is the bible. So it doesn't matter to me what anyone has done to the index, I will update it from the project Log(excel) file.
Manually this can take over an hour to do, but with the script provided by RONJONP this can be accomplished in about 10 min. It's pretty good. I would like to cut minutes down to seconds. I will be looking to tweak it a bit further, but the heavy lifting is done.
I would still prefer to go directly to the project EXCEL spreadsheet and skip having to make a CSV file, and skip having to align the text to the proper X values for the columns. Since the location of the data in the spreadsheet is always exactly the same.
Baby steps.
