Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Biscuits on March 12, 2008, 01:51:56 PM
Using Windows XP with Autocad2008.
I'm looking for a routine to select an attribute (to obtain text height)
then select other attributes to change their text height to match the previous selection.
Would appreciate any assistance with this.
Look at 'nentsel' to select the first attribute. Then grab the Height property. Then use the routine here (http://www.theswamp.org/index.php?topic=19886.0) to select the other attributes.
Need more?
(setq en1 (entget (car (nentsel))))
(setq en2 (cdr (assoc 40 en1)))
So, any progress?
Poor lsp skills and time constraints are my excuses for little progress for now.
Not sure how to combine your statements with T.Willey's
Thanks for your help
I'll see if I can whip something up for you then. I've got a little time.
My general disclaimer applies - "It aint pretty but it works"
There is a regen after each selection, and the variables aren't reset, but I've run out of time to make it a bit more friendly. Others here could probably do quite a bit better, but hey, it works.
Enjoy!
;match_att_ht.lsp
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;start prog
(defun c:match_att_ht ()
(setq cntr1 1)
(while (= 1 cntr1)
(setq ent1 (nentsel "\nSelect any text object <HIT ESC TO STOP>:" ))
(setq en1-2 (car ent1))
(setq en3 (entget (car Ent1)))
(setq en3
(subst(cons 40 en2)
(assoc 40 en3)
en3))
(entmod en3)
(entupd en1-2)
(command "regen")
);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;while
Lookin' purty to me!
Thank you.
Works great.
Not a problem (today anyway)!
