MC, I came to the same conclusion last night about the line between circles that don't overlap. I was going to test that approach this evening. I do provide an option to allow a point & measurement to be removed from consideration if it appears that it was recorded in error...I have a form showing the points used, the measured values, and the Residual amount the calculated point is from the actual measured distance. The residual, in practice, should be typically <a few tenths, so if the user sees a large discrepancy they can remove a point (if more than 3 were used) to get a valid location.
Mark, thanks for that. I will do some more investigating before I complete this project.
