Author Topic: Help with Selection Set  (Read 2299 times)
polhub
« on: October 29, 2018, 07:26:24 AM »
Ronjonp wrote this awsome bit of code. Each SL-WIRE-FLAG block has a line associated with it, the question is,  how would I go about adding a line to the selection set, is it part of the DXF code or is it a separate selection set altogether?
  1. (defun c:foo (/ a b bp c l mp p p1 p2 s x x1 x2 y y1 y2 _x _y)
  2.   ;; RJP - 11.15.2017
  3.   (if (and (setq p1 (getpoint "\nSpecify first corner: "))
  4.            (setq p2 (getcorner p1 "\nSpecify opposite corner:"))
  5.            (setq l (list p1 p2))
  6.            (setq l (list (apply 'mapcar (cons 'min l)) (apply 'mapcar (cons 'max l))))
  7.            (setq s (ssget "_C" p1 p2 '((0 . "insert") (2 . "`*U*,SL-WIRE-FLAG"))))
  8.            (setq p
  9.                   (mapcar
  10.                     '(lambda (x)
  11.                        (if (setq p1 (vl-remove-if-not
  12.                                       '(lambda (c) (wcmatch (strcase (vla-get-propertyname c)) "POSITION*"))
  13.                                       (vlax-invoke x 'getdynamicblockproperties)
  14.                                     )
  15.                            )
  16.                          (list (vl-sort p1
  17.                                         '(lambda (a b) (< (vla-get-propertyname a) (vla-get-propertyname b)))
  18.                                )
  19.                                (vlax-get x 'insertionpoint)
  20.                          )
  21.                        )
  22.                      )
  23.                     (vl-remove-if-not
  24.                       '(lambda (d) (vlax-write-enabled-p d))
  25.                       (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  26.                     )
  27.                   )
  28.            )
  29.            (setq bp (getpoint "\nSpecify base point: "))
  30.            (setq mp (getpoint bp "\nSpecify second point: "))
  31.       )
  32.     (foreach x (vl-remove 'nil p)
  33.       (mapcar 'set '(x1 y1 x2 y2) (mapcar '(lambda (y) (vlax-get y 'value)) (setq c (car x))))
  34.       (setq _x (car (cadr x)))
  35.       (setq _y (cadr (cadr x)))
  36.       (if (setq a (cond ((and (<= (car (mapcar 'car l)) (+ _x x1) (cadr (mapcar 'car l)))
  37.                               (<= (car (mapcar 'cadr l)) (+ _y y1) (cadr (mapcar 'cadr l)))
  38.                          )
  39.                          (list (car c) (cadr c) (list x1 y1))
  40.                         )
  41.                         ((and (<= (car (mapcar 'car l)) (+ _x x2) (cadr (mapcar 'car l)))
  42.                               (<= (car (mapcar 'cadr l)) (+ _y y2) (cadr (mapcar 'cadr l)))
  43.                          )
  44.                          (list (caddr c) (cadddr c) (list x2 y2))
  45.                         )
  46.                   )
  47.           )
  48.         (progn (setq b (polar (last a) (angle bp mp) (distance bp mp)))
  49.                (vlax-put (car a) 'value (car b))
  50.                (vlax-put (cadr a) 'value (cadr b))
  51.         )
  52.       )
  53.     )
  54.   )
  55.   (princ))
Re: Help with Selection Set
« Reply #1 on: October 30, 2018, 09:38:36 AM »
Not a lot of time to modify this, but this might work:
  1. (defun c:foo (/ a b bp c l mp p p1 p2 s s2 x x1 x2 y y1 y2 _x _y)
  8.            (setq s2 (ssget "_C" p1 p2 '((0 . "line"))))
  9.            (setq p
  10.                   (mapcar
  11.                     '(lambda (x)
  12.                        (if (setq p1 (vl-remove-if-not
  13.                                       '(lambda (c) (wcmatch (strcase (vla-get-propertyname c)) "POSITION*"))
  14.                                       (vlax-invoke x 'getdynamicblockproperties)
  15.                                     )
  16.                            )
  17.                          (list (vl-sort p1
  18.                                         '(lambda (a b) (< (vla-get-propertyname a) (vla-get-propertyname b)))
  19.                                )
  20.                                (vlax-get x 'insertionpoint)
  21.                          )
  22.                        )
  23.                      )
  24.                     (vl-remove-if-not
  25.                       '(lambda (d) (vlax-write-enabled-p d))
  26.                       (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  27.                     )
  28.                   )
  29.            )
  30.            (setq bp (getpoint "\nSpecify base point: "))
  31.            (setq mp (getpoint bp "\nSpecify second point: "))
  32.       )
  33.     (progn (foreach x (vl-remove 'nil p)
  34.              (mapcar 'set '(x1 y1 x2 y2) (mapcar '(lambda (y) (vlax-get y 'value)) (setq c (car x))))
  35.              (setq _x (car (cadr x)))
  36.              (setq _y (cadr (cadr x)))
  37.              (if (setq a (cond ((and (<= (car (mapcar 'car l)) (+ _x x1) (cadr (mapcar 'car l)))
  38.                                      (<= (car (mapcar 'cadr l)) (+ _y y1) (cadr (mapcar 'cadr l)))
  39.                                 )
  40.                                 (list (car c) (cadr c) (list x1 y1))
  41.                                )
  42.                                ((and (<= (car (mapcar 'car l)) (+ _x x2) (cadr (mapcar 'car l)))
  43.                                      (<= (car (mapcar 'cadr l)) (+ _y y2) (cadr (mapcar 'cadr l)))
  44.                                 )
  45.                                 (list (caddr c) (cadddr c) (list x2 y2))
  46.                                )
  47.                          )
  48.                  )
  49.                (progn (setq b (polar (last a) (angle bp mp) (distance bp mp)))
  50.                       (vlax-put (car a) 'value (car b))
  51.                       (vlax-put (cadr a) 'value (cadr b))
  52.                )
  53.              )
  54.            )
  55.            ;; Move lines in selection set
  56.            (and s2 (command "_.move" s2 "" bp mp))
  57.     )
  58.   )
  59.   (princ)
  60. )
Coder
« Reply #2 on: October 30, 2018, 09:52:41 AM »
I am not doing great with Autolisp yet but maybe you need to turn off osmode before command move.  :wink:
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: October 31, 2018, 03:04:27 AM »
Would it be easier to use Group linking the block and the line, do the move then Ungroup
polhub
« Reply #4 on: October 31, 2018, 09:00:43 AM »
Thanks RonJonP! Works great!
I see you just added a separate selection set, I was trying to merge it with the first but had no luck. I do have a question, it seems that the identified block SL-Wire-Flag is not the only block selected it selects other dynamic blocks as well. Is that because of the below statement? I only ask because I believe I have several blocks with a move position in them (which I can easily change)
Thanks you for your help (the Swamp really needs a thumbs up emogee).
« Last Edit: October 31, 2018, 09:06:23 AM by polhub »
« Reply #5 on: October 31, 2018, 09:31:25 AM »
Glad it worked for you :). If you'd like to only filter out the "SL-WIRE-FLAG" block replace this:
  1. (vl-remove-if-not
  2.   (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  3. )
with this:
  2.   '(lambda (d)
  3.      (or (eq "SL-WIRE-FLAG" (strcase (vla-get-effectivename d))) (vlax-write-enabled-p d))
  4.    )
  6. )
