Author Topic: Modify 2nd element of Dotted Pair List  (Read 4357 times)
mailmaverick
« on: December 18, 2015, 05:37:48 AM »
I am having a dotted pair list. For example :-
(setq wallinfo (list sublist (cons 'len 240.0) (cons 'hgt 96.0)))
((LYR . "WALLS") (LEN . 240.0) (HGT . 96.0))
I want to modify Length from 240 to 280. How to do that ?
Re: Modify 2nd element of Dotted Pair List
« Reply #1 on: December 18, 2015, 05:51:23 AM »
Try this :
  1. (setq wallinfo '(("LYR" . "WALLS") ("LEN" . 240.0) ("HGT" . 96.0)))
  2.
  3. (KDUB:replace-assoc "LEN" 280.0 'wallinfo)
  1.
  2. ;;;------------------------------------------------------------------
  3. ;;;------------------------------------------------------------------
  4. ;;;
  5. ;;; a general utility -- replace cons list from assoc list
  6. ;;; say tmp_list is= (("EXPERT" . 2) ("TEXTSIZE" . 3.5) ("BLIPMODE" . 0))
  7. ;;; (KDUB:replace-assoc "TEXTSIZE" 5.0 'tmp_list)
  8. ;;;     ==>(("EXPERT" . 2)("TEXTSIZE" . 5.0)("BLIPMODE" . 0))
  9. ;;; note : Removes first found reference only
  10. ;;; to replace the last matching cons in list :
  11. ;;; (setq tmp_list (reverse tmp_list)
  12. ;;;       tmp_list (reverse (KDUB:replace-assoc .... 'tmp_list)))
  13. ;;;
  14. (defun kdub:replace-assoc (assoctag assocval quoted_lst_sym)
  15.   (set quoted_lst_sym
  16.        (subst (cons assoctag assocval)
  17.               (assoc assoctag (eval quoted_lst_sym))
  18.               (eval quoted_lst_sym)
  19.        )
  20.   )
  21. )
  22.
kpblc
« Reply #2 on: December 18, 2015, 05:55:45 AM »
I'm using this function:
  1. (defun _kpblc-list-add-or-subst (lst key value)
  2.                                 ;|
  3. *    Change or add list by key
  4. *    Call parameters:
  5.   lst      list to be proceed
  6.   key      key
  7.   value    value to be set. nil - erase sublist
  8. *    Call samples:
  9. (setq lst '((1 . 2) ("test" . "value0")))
  10. (_kpblc-list-add-or-subt lst "test" 1) ; '((1 . 2) ("test" . 1))
  11. (_kpblc-list-add-or-subt lst "test2" 1) ; '((1 . 2) ("test" . "value0") ("test2" . 1))
  12. (_kpblc-list-add-or-subt lst "test" nil) ; '((1 . 2))
  13. |;
  14.   (if (not value)
  15.     (vl-remove-if (function (lambda (x) (= (car x) key))) lst)
  16.     (if (cdr (assoc key lst))
  17.       (subst (cons key value) (assoc key lst) lst)
  18.       (cons (cons key value)
  19.             (vl-remove-if
  20.               (function
  21.                 (lambda (x)
  22.                   (= (car x) key)
  23.                   ) ;_ end of lambda
  24.                 ) ;_ end of function
  25.               lst
  26.               ) ;_ end of vl-remove-if
  27.             ) ;_ end of cons
  28.       ) ;_ end of if
  29.     ) ;_ end of if
  30.   ) ;_ end of defun
Sorry for my English.
AIberto
« Reply #3 on: December 18, 2015, 06:11:30 AM »
Very good example, Thanks Kerry & kpblc.
« Reply #4 on: December 18, 2015, 06:23:17 AM »
Thanks AIberto.
roy_043
  • BricsCAD 18
« Reply #5 on: December 18, 2015, 07:45:36 AM »
@ kpblc:
If you change line 16 to:
(if (assoc key lst)You can replace lines 19-26 with just:
lst
Note that line 15 will remove all subs with an identical key and that subst in line 17 will only substitute the first. So your function assumes a list with unique keys.
Edit: This is not exactly correct. Subst will replace all occurrences of an item in a list. But the function does assume unique keys:
(_kpblc-list-add-or-subst '((1 . 2) (1 . 3) (1 . 4)) 1 nil)
=> nil
(_kpblc-list-add-or-subst '((1 . 2) (1 . 3) (1 . 4)) 1 5)
=> ((1 . 5) (1 . 3) (1 . 4))
« Last Edit: December 18, 2015, 08:23:22 AM by roy_043 »
Marc'Antonio Alessi
  • Marco
« Reply #6 on: December 18, 2015, 08:20:49 AM »
Try this :
  2.
Let me ask, why not simply?
(defun kdub:replace-assoc2 (assoctag assocval lst_sym)
     (assoc assoctag lst_sym)
     lst_sym
(setq wallinfo (KDUB:replace-assoc2 "LEN" 280.0 wallinfo))
=> (("LYR" . "WALLS") ("LEN" . 280.0) ("HGT" . 96.0))
efernal
« Reply #7 on: December 18, 2015, 09:07:15 AM »
  1. (SETQ sublist (CONS 'lyr "WALLS"))
  2. (SETQ wallinfo (LIST sublist (CONS 'len 240.0) (CONS 'hgt 96.0)))
  3. (SETQ wallinfo (SUBST (CONS 'len 280.0) (ASSOC 'len wallinfo) wallinfo))
  4.
  5. (LYR . "WALLS")
  6. ((LYR . "WALLS") (LEN . 240.0) (HGT . 96.0))
  7. ((LYR . "WALLS") (LEN . 280.0) (HGT . 96.0))
  8.
e.fernal
« Reply #8 on: December 18, 2015, 07:21:39 PM »
@Marc
Yes, I posted the version I use for experimenting ..
Still works in this situation
.. though this may suit the OP better
  1. (defun kdub:replace-assocVal (tag val lst)
  2.   (subst (cons tag val) (assoc tag lst) lst)
  3. )
@efernal
Yes, I ignored the OP's key naming was using SYM's for the key ... my bad!
If he really wants to define the assoc list like that then a different  function will need to be crafted as you have done.
Fortunately, this still works :
  1. (setq wallinfo (KDUB:replace-assocVal 'len  280.0 wallinfo)
  2. ;or
  3. (KDUB:replace-assoc 'len  280.0 'wallinfo)
  4.
@mailmaverick
Did you mean to assign the key values as Symbols like that ??
« Last Edit: December 18, 2015, 07:37:40 PM by Kerry »
mailmaverick
« Reply #9 on: December 19, 2015, 09:36:15 AM »
@mailmaverick
In my list, name shall always be STRING such as LEN, HGT etc. and associated value shall be real number.
Marc'Antonio Alessi
  • Marco
« Reply #10 on: December 19, 2015, 11:08:24 AM »
Therefore your list will look like:
(setq wallinfo (list sublist (cons "LEN" 240.0) (cons "HGT" 96.0)))
mailmaverick
« Reply #11 on: December 20, 2015, 10:57:08 AM »
Thanks to all.
My problem has been solved. !!!!
