Author Topic: Can't open the file  (Read 3612 times)
Fabricio28
Can't open the file
« on: December 11, 2015, 01:31:20 PM »
Hi guys,
I've received a project and I can't open it.
I'm trying to use recover command and isn't working.
Anybody can help me please?
Regards
Re: Can't open the file
« Reply #1 on: December 11, 2015, 02:06:08 PM »
I can open it reports 257 errors!
« Reply #2 on: December 11, 2015, 02:08:56 PM »
audit and recover both report ONLY 2 items fixed/repaired?
« Reply #3 on: December 11, 2015, 02:11:49 PM »
I see this for annotation scales when opening:
Fabricio28
« Reply #4 on: December 11, 2015, 02:12:37 PM »
Hi mjfarrell,
Thank you very much.
Now I can open the file.  :-D
Fabricio28
« Reply #5 on: December 11, 2015, 02:15:06 PM »
Hi ron
How are you?
I don't know what  happened to the scale.
Fabricio28
« Reply #6 on: December 11, 2015, 02:18:11 PM »
How can you fix it??
« Reply #7 on: December 11, 2015, 02:29:18 PM »
ANNORESET
Fabricio28
« Reply #8 on: December 11, 2015, 02:47:15 PM »
ANNORESET
I can open the file to use ANNORESET.
« Reply #9 on: December 11, 2015, 05:05:00 PM »
yes..open file
do
annoreset
Fabricio28
« Reply #10 on: December 14, 2015, 06:28:18 AM »
yes..open file
do
annoreset
Hi mjfarell
I can't open the file. The autocad close the file.
« Reply #11 on: December 14, 2015, 08:33:39 AM »
so, now you can not open the file I posted?
try rename the BAK of that one you opened earlier.
Fabricio28
« Reply #12 on: December 14, 2015, 09:17:41 AM »
Sorry mjfarrell
But I'm not understanding.
There isn't any BAK to rename. The autocad wasn't created that file because I can't open, I think
I have only dwg file.
Thank in advance my friend. :)
Crank
« Reply #13 on: December 19, 2015, 10:22:08 AM »
Fabricio,
If ANNORESET doesn't work for you, then you can use SCALELISTEDIT and delete the scales that aren't used.
The attached drawing is already clean.
