Author Topic: need help loading swlayout.dvb  (Read 2173 times)
ELOQUINTET
« on: February 04, 2005, 09:52:01 AM »
i recently found this file which says you can use it to switch layout tabs using control keys. i went into vba manager and loaded it but how do i use it? has anyone seen this and knows if it works or what i may be doing wrong i'm not that familiar with loading vba yet?
hendie
« Reply #1 on: February 04, 2005, 10:12:51 AM »
if you have a few layouts in your drawing and you're a keyboard maestro, you can navigate through the layouts by using the CONTROL + PAGEUP or CONTROL + PAGEDOWN keys (for 2004 and above)
from the ResourceCAD tiips and tricks forum (or you could use the LORG download)
ELOQUINTET
« Reply #2 on: February 04, 2005, 12:03:44 PM »
yeah i'm aware of the ability to do it with page up and down but we're using 2002. i also downloaded lorg but how do i load and use this? thanks
ELOQUINTET
« Reply #3 on: February 04, 2005, 12:14:11 PM »
nevermind hendie i installed again and got it to work, not sure what happened before but it's fine now. it would be cool if i could scroll through using the keyboard though  :cry:
