Author Topic: VLsip Editior Help  (Read 1853 times)
One Shot
VLsip Editior Help
« on: April 25, 2005, 06:16:59 PM »
When you debug in VLisp, do you input each line of lisp into the console?  How do you run the animate option for it also?
Thank you,
Brad
daron
VLsip Editior Help
« Reply #1 on: April 26, 2005, 07:44:12 AM »
I highlight the section I want tested and select the microscope toolbar. For animate, select the option, load using the "load active window" button, then run the command in autocad. Works well sometimes and other times, it can be goofy. Also, it can be a bear on long iterations. Use it with caution.
VLsip Editior Help
« Reply #2 on: April 26, 2005, 08:18:07 AM »
Just so you know I'm not ignoring this thread I don't use the VLIDE editor. Generally speaking, breaking programs into consise, do only one thing functions lends itself to very easy debugging, so the animate thing has never been something I needed. I can see how it would be useful though, particularly in monolithic style programming. This is not a veiled shot, just my observation.
