Author Topic: Convert blocks to xrefs?  (Read 2347 times)
ArgV
« on: January 06, 2010, 10:04:58 AM »
Hello.
I didn't find anything right off by searching, and not even sure if this realistic or not, but I want to be able to swap out all blocks with xrefs (pulled from a folder of my choosing). I got it to *kinda* work, but obviously if block already exists I need to copy the remaining xref rather than do the vla-attachexteralreference property.
but I'd rather see if anyone knows if this is even possible.
thank you,
ArgV
Joe Burke
Re: Convert blocks to xrefs?
« Reply #1 on: January 06, 2010, 10:13:36 AM »
Have you tried the ExpressTools command "blocktoxref"?
ArgV
« Reply #2 on: January 06, 2010, 06:35:29 PM »
NO! :) I was typing stuff like that trying to see if there was a command like that. Cool, I'll try that. :)
thank you.
