Author Topic: Plot Tabs Routine  (Read 13079 times)
Plot Tabs Routine
« Reply #15 on: December 17, 2003, 08:43:46 AM »
dan,
Found another problem with plotting to device and corrected it,
So copy the lisp routine again before trying it.
ELOQUINTET
Plot Tabs Routine
« Reply #16 on: December 17, 2003, 08:51:13 AM »
hey cab i recopied the code and tried what you said but still get the same results. nothing prints and no plt file created either. i check save page setup to layout and set it to tabs and uncheck plot to file and it reverts back to alpha and plt?
dan
Plot Tabs Routine
« Reply #17 on: December 17, 2003, 08:59:51 AM »
Sorry dan, I didn't post the last message before you got here.
I just fixed that, try again please.
daron
Plot Tabs Routine
« Reply #18 on: December 17, 2003, 09:17:28 AM »
Quote from: eloquintet
thanks cab i'll give that a try. daron i believe mark knows i'm just playin around.  :wink:
dan
I know you are. I just felt like giving you a hard time too.
ELOQUINTET
Plot Tabs Routine
« Reply #19 on: December 17, 2003, 01:23:34 PM »
welp copied it again and still nothing hmmm?
Plot Tabs Routine
« Reply #20 on: December 17, 2003, 04:03:41 PM »
OK dan, one more time   :)
Some dcl code was giving me a fit.
Hope that clears it up.
ELOQUINTET
Plot Tabs Routine
« Reply #21 on: December 17, 2003, 04:55:11 PM »
now when i run it it says can't find plottabs.dcl  :cry:
daron
Plot Tabs Routine
« Reply #22 on: December 17, 2003, 04:58:02 PM »
Where's the dcl located? Is it in a pathed folder?
Plot Tabs Routine
« Reply #23 on: December 17, 2003, 05:06:31 PM »
dan, my fault, I am working an another version & i renamed the dcl file.
SO eather copy the lisp again, which i revised the name back to PLotTabs.dcl.
Or rename the dcl PLotTabs2.dcl.
But do not do both.
ELOQUINTET
Plot Tabs Routine
« Reply #24 on: January 09, 2004, 08:36:29 AM »
cab what's the status of your plottabs routine. i'm not sure which code to copy to have it work. i'm still using the original before you added the dcl. can you post what you have so i can try it out. thank
ELOQUINTET
Plot Tabs Routine
« Reply #25 on: January 09, 2004, 08:45:15 AM »
ok copied the code and got it working but it still sets alpha and plot to file as default rather than not but hey beggars can't be choosers i guess. thanks man
Anonymous
Plot Tabs Routine
« Reply #26 on: April 20, 2004, 06:08:01 PM »
I copied your lisp and dcl, but when I load the lisp, I get this:
error: bad character read (octal): 0
Any Ideas
Scott
Scott
Plot Tabs Routine
« Reply #27 on: April 20, 2004, 06:10:04 PM »
Sorry,
I cleaned out my cookies, and forgot to log in.  The above post is from me.
Thanks Again
Scott
Plot Tabs Routine
« Reply #28 on: April 20, 2004, 06:20:32 PM »
The dcl file must be in the acad search path, is that it?
Scott
Plot Tabs Routine
« Reply #29 on: April 21, 2004, 03:29:52 PM »
Yes, both lisp and dcl are in a file called LSP in the autocad search path.
