Author Topic: Block ATT number Move Layer with ATT number  (Read 1179 times)
Hugo
« on: August 11, 2016, 12:57:05 AM »
Hello
Does anyone have a Lisp where you can move a block with ATT-number on the correct layer. (see image)
I mean it, all blocks with ATT number                    920 / .. Layer __20-Linie_920
        921 / .. Layer __21-Linie_921
        etc.
Thanks Heinz
Block ATT-Nummer verschieben auf Layer mit ATT-Nummer
Hallo
Hat jemand ein Lisp wo man einen Block mit ATT-Nummer auf den richtigen Layer verschieben kann. (siehe Bild)
Ich meine das so, alle Blöcke mit ATT-Nummer     920/.. auf Layer __20-Linie_920
        921/.. auf Layer __21-Linie_921
        usw.
Danke Heinz
Hugo
Re: Block ATT number Move Layer with ATT number
« Reply #1 on: August 12, 2016, 12:31:03 AM »
ok Thank se can not help.
mfg Heinz
danallen
« Reply #2 on: August 12, 2016, 12:44:30 AM »
searching the swamp: https://www.google.com/search?q=site%3Atheswamp.org+select+block+attribute+value
first post has filter for blocks by attribute value https://www.theswamp.org/index.php?topic=40933.0
that gets you started, if all the attributes are just numbers XYZ moved to layers in pseudo code (strcat "__" YZ "-Linie_" XYZ), it shouldn't be too hard to work something up.
If you are looking for someone to do it all for you, I wish you best of luck. If you can start drafting the code and need help, you'll get lots.
Dan
Hugo
« Reply #3 on: August 12, 2016, 03:00:31 AM »
OK DANKE
 :-D :-D :-D
