Our drawings are set up with an attributed Title Block and a separate Revision Block or blocks. Our EDMS (Also Adept) only looks in our Title Block for extraction data. For the purpose of OUR database, it was not necessary to populate it with items such as 'Drawn By', 'Checked By', or 'Approved By'. All we extract is four lines of drawing title, Rev, and two other (now meaningless) fields. This facility has been around for a while and has umpteen different borders, title blocks, attributes, etc. so it makes this process a little more difficult because for each attribute or field, we currently have up to 18 different attribute tags for the first line, revision (etc.) fields.
Sorry for the run on blabbering...
As Hendie mentioned, look for the Administrator's settings (or an administrator) to change the method in which your attributes are 'pulled' or 'pushed' from / to your drawings. If that isn't possible, Andy's suggestion might be worth looking into.
/ my 2¢
