Author Topic: "exp10" no function definition  (Read 1935 times)
Peter2
« on: March 03, 2016, 02:03:35 PM »
Help files for 2011, 2014 and 2016 tell me:
exp10(real): Base-10 exponent of the number
My result is:
Befehl: (exp 2)
7.38906
Befehl: (exp10 2)
; Fehler: no function definition: EXP10
Befehl: (exp10 2.0)
Befehl: (exp10)
Befehl: (sin 2)
0.909297
Befehl: (exp 2)
7.38906
Befehl: (sqrt 7.38)
2.71662
Befehl: (cos 2)
-0.416147
Befehl: (log 2)
0.693147
Befehl: (exp10 2.0)
Befehl: (exp10 200.0)
Befehl: (exp10 0.01)
"exp10" was not found here at The Swamp, not in AutoCAD forums, not at AfraLisp, and only mentioned, not used at CadTutor
Help-file wrong?
Peter
BricsCAD V23
Re: "exp10" no function definition
« Reply #1 on: March 03, 2016, 02:15:56 PM »
exp10() is a function for use in formula fields.
expt is the AutoLISP function you are looking for:
  1. _$ (expt 10 2)
  2. 100
Peter2
« Reply #2 on: March 03, 2016, 02:21:16 PM »
exp10() is a function for use in formula fields....
Sorry - my (really) bad. Via search I found the help side, but ignored that it is related (only) to "cal"  :oops:
Peter
BricsCAD V23
« Reply #3 on: March 03, 2016, 02:33:45 PM »
No worries!
Just for fun -
If the expt function didn't exist, you could also use exp in the following way:
  1. _$ (defun myexpt ( a b ) (exp (* b (log a))))
  2. MYEXPT
  3. _$ (myexpt 10 2)
  4. 100.0
« Last Edit: March 03, 2016, 02:38:19 PM by Lee Mac »
