Author Topic: Frame Height - Another Part Builder Question  (Read 5120 times)
dfarris75
Re: Another Part Builder Question
« Reply #15 on: December 30, 2010, 10:22:40 PM »
It's a pitch to help you folks remotely in any way I can.
I'd need the local criteria...I think there is a way we could work something out....it just takes a little imagination.
Near everything you'd need is on the city website. www.coj.net or on www.municode.com.
You could find the standard storm structures here.
Sanitary Structures here.
Structure Rim Height question in Part Builder
« Reply #16 on: December 30, 2010, 10:48:27 PM »
Why is it that after modifying part dims in part builder (as I just did earlier) I have to swap the part out with itself? Why doesn't it just modify all instances of the part in the dwg after modifying it in part builder?
that would be a quirk only answerable by those wise elves at autodesk
you know, just because the model is dynamic
doesn't mean that the part builder parts are
 :ugly:
