Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Adesu on March 02, 2010, 07:27:23 PM
I would change function for zoom, but for zoom real time not work,any one have idea?
(defun c:za ()
(command "_zoom" "a")
(defun c:zc ()
(command "_zoom" "c")
(defun c:zd ()
(command "_zoom" "d" "")
(defun c:ze ()
(command "_zoom" "e")
(defun c:zp ()
(command "_zoom" "p")
(defun c:zs ()
(command "_zoom" "s")
(defun c:zw ()
(command "ZOOM" "W" pause pause)
(defun c:zo ()
(command "_zoom" "o")
(defun c:zr ()
(command "_zoom" "r") ; this code not work
Doing it this way works the same as if you type it in so Zoom R won't do anything. Try:
(command "_zoom" "")
it great, thanks
Or you can use the command RTZOOM.
:evil:Yes,You are right!
why not use the pgp file for this?
