Author Topic: Block on layer zero without moving the attributes  (Read 2806 times)
Hugo
« on: April 08, 2011, 03:32:35 AM »
Hello
Have you a Lisp where everything is placed on Lyer null move without me the attribute.
This is a very good thing
Now I want but the shading is not placed on layer zero but will remain as it is
Can I use the one in the Installation Procedure Lisp.
Hallo
Habe ihr ein Lisp wo alles auf Lyer null gelegt wird ohne mir das Attribut zu verschieben.
Das läuft sehr gut so
Jetzt will ich aber das die Schraffur nicht auf Layer null gelegt wird sondern so bleibt wie sie ist
Kann mir bitte das einer in die Lisp einbaun.
Danke
Hugo
Re: Block on layer zero without moving the attributes
« Reply #1 on: April 08, 2011, 03:35:58 AM »
Sorry Lisp
(defun c:ATTColor (/ blkobj lays ss)
  (setq lays (vla-get-layers
ss   (ssget "x" '((0 . "INSERT") (66 . 1)))
  (if ss
      (setq ss
     (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))
      (mapcar
'(lambda (b)
   (if (eq (vla-get-lock (vla-add lays (vla-get-layer b)))
   :vlax-false
       (mapcar
'(lambda (a)
    (vla-put-color a 256)
(vlax-invoke b 'getattributes)
       (vlax-for blkobj (vla-item
  (vla-get-blocks
  (vla-get-name b)
(mapcar
   '(lambda (c)
      (vla-put-color blkobj 256)
     (princ (strcat "\n Block "
    (vla-get-name b)
    " on locked layer "
    (vla-get-layer b)
    " not updated..."
ss
« Reply #2 on: April 08, 2011, 08:34:28 AM »
« Reply #3 on: April 08, 2011, 09:02:50 AM »
Another example - will move block objects and attributes to an arbitrary layer (currently set to layer "0") and with color ByLayer:
([color=BLUE]defun[/color] c:Ins2Layer ( [color=BLUE]/[/color] acblk acdoc acsel done layer name ) ([color=BLUE]vl-load-com[/color])
  [color=GREEN];; Example © Lee Mac 2011  -  www.lee-mac.com[/color]
  ([color=BLUE]setq[/color] acdoc ([color=BLUE]vla-get-ActiveDocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))
        acblk ([color=BLUE]vla-get-Blocks[/color] acdoc)
  ([color=BLUE]setq[/color] layer [color=MAROON]"0"[/color]) [color=GREEN];; Layer for Block Objects[/color]
  ([color=BLUE]if[/color] ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"INSERT"[/color])))
    ([color=BLUE]progn[/color]
      ([color=BLUE]vlax-for[/color] block ([color=BLUE]setq[/color] acsel ([color=BLUE]vla-get-ActiveSelectionSet[/color] acdoc))
        ([color=BLUE]foreach[/color] attrib
          ([color=BLUE]append[/color] ([color=BLUE]vlax-invoke[/color] block 'getattributes) ([color=BLUE]vlax-invoke[/color] block 'getconstantattributes))
          ([color=BLUE]vla-put-layer[/color] attrib layer)
          ([color=BLUE]vla-put-color[/color] attrib [color=BLUE]acbylayer[/color])
        ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]member[/color] ([color=BLUE]setq[/color] name ([color=BLUE]vla-get-name[/color] block)) done))
          ([color=BLUE]vlax-for[/color] object ([color=BLUE]vla-item[/color] acblk ([color=BLUE]car[/color] ([color=BLUE]setq[/color] done ([color=BLUE]cons[/color] name done))))
            ([color=BLUE]vla-put-layer[/color] object layer)
            ([color=BLUE]vla-put-color[/color] object [color=BLUE]acbylayer[/color])
      ([color=BLUE]vla-delete[/color] acsel) ([color=BLUE]vla-regen[/color] acdoc [color=BLUE]acallviewports[/color])
  ([color=BLUE]princ[/color])
Hugo
« Reply #4 on: April 08, 2011, 12:57:39 PM »
Thanks Lee
But should he not change the shading, otherwise ok
Danke Lee
Aber die Schraffur sollte er nicht ändern, sonst ok
Hugo
« Reply #5 on: April 08, 2011, 01:33:42 PM »
You may want to look at this one too:
http://www.cadtutor.net/forum/archive/index.php/t-47075.html
Thanks CAB
Also not what I want.
Danke CAB
Auch nicht das was ich suche.
Hugo
« Reply #6 on: April 12, 2011, 09:59:02 AM »
Hello
I Can not Help the the hatch is not changed.
Hallo
Kann mir keiner Helfen das die Schraffur nicht geändert wird.
Danke
