Author Topic: [XDrX-PlugIn(160)] extend or cut curve with circle  (Read 265 times)
xdcad
« on: May 02, 2024, 11:47:44 AM »
https://www.cadtutor.net/forum/topic/67785-how-to-extend-or-cut%EF%BC%9F/
(defun c:xdtb_cirextend (/ box clone ints nearpt pnt r ss ss1 strepnts x y z)
  (xd::doc:getdouble (xdrx-string-multilanguage "\n圆半径" "\nCircle Radius")
     "#mradius" 10.0
  (if (setq ss (xdrx-ssget (xdrx-string-multilanguage "\n选择圆<退出>:" "\nSelect Circle<Exit>:")
   '((0 . "circle"))
      (mapcar
'(lambda (x)
   (setq r (xdrx-getpropertyvalue x "radius")
box (xdrx-entity-box x)
box (xd::pnts:close box)
   (setq clone (xdrx-object-clone x))
   (xdrx-setpropertyvalue x "radius" #mradius)
   (if (setq ss1 (ssget "f" box '((0 . "*polyline,line"))))
       (mapcar
'(lambda (y)
    (setq strepnts (xdrx-entity-getstretchpoint y))
    (if (setq pnt (vl-some '(lambda (z)
      (if (xdrx-point-ison z clone)
z
    ) strepnts
(if (setq ints (xdrx-entity-intersectwith y x 1))
    (setq nearpt (xdrx-points-nearpt pnt ints))
    (xdrx-entity-movestretchpointex y pnt
    (mapcar
      nearpt
      pnt
(xdrx-ss->ents ss1)
   (xdrx-entity-delete clone)
(xdrx-ss->ents ss)
https://github.com/xdcad
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
