Author Topic: Connection with Ms Access  (Read 2519 times)
Ricky_76
« on: July 04, 2007, 02:22:15 AM »
Hi, I have some problem connecting access via vb.net!
I need 3 sub routines to GET, PUT and UPDATE records!
the GET routine works very well
    Public Sub db_Get(ByVal Tabella As String, ByVal Campo As String, ByRef Destinazione As String, Optional ByVal Filtro As String = "", Optional ByVal FiltroValue As String = "")
        Dim ConnString As String = "Provider=Microsoft.Jet.OLEDB.4.0;" & "Data Source=" & PercorsoDB & NomeDB
        Dim Cn As New OleDbConnection(ConnString)
        Cn.Open()
        'recupera i dati dal db
        Destinazione = ""
        Select Case Filtro
            Case ""
                Dim sql_MC As String = "select * from " & Tabella
                Dim cmd_MC As New OleDbCommand(sql_MC, Cn)
                Dim dr_MC As OleDbDataReader = cmd_MC.ExecuteReader
                Do While dr_MC.Read()
                    Destinazione = (dr_MC.Item(Campo))
                Loop
            Case Else
                Dim sql_MC As String = "select * from " & Tabella & " where " & Filtro & "=?"
                cmd_MC.Parameters.AddWithValue(Filtro, FiltroValue)
                    Destinazione = (dr_MC.Item(Campo).ToString)
                Loop
        End Select
        Cn.Close()
the PUT routine works very well too
        Sub putDB(ByVal t As Margot.Contatto)
            If t.FTP.ToString = "" Then t.FTP = "NO"
            If t.Fornitore = "" Then t.Fornitore = "NO"
            If t.Cliente = "" Then t.Cliente = "NO"
            If t.RisorsaInterna = "" Then t.RisorsaInterna = "NO"
            If t.EsenteEPAP = "" Then t.EsenteEPAP = "NO"
            Dim PercorsoDB As String = "W:\00_00_00 - Programma_Gestione\File_Mdb\"
            Dim NomeDB = "Margot.mdb"
            Dim a As String = "', '"
            Cn.Open()
            If t.Cognome <> "" Then
                Dim sql_MC As String = "INSERT INTO Tab_Contatti (Cognome, Nome, Societą, wIndirizzo, wCAP, wCittą, wProvincia, Accesso_FTP_Arcadia, FTP_User, FTP_Pwd,Cliente,Fornitore,EsenteEPAP,Risorsa_Interna, wMail) VALUES ('"
                sql_MC &= t.Cognome & a & t.Nome & a & t.Societą & a & t.wIndirizzo & a & t.wCap & a & t.wCittą & a & t.wProvincia & a & t.FTP & a & t.FTP_User & a & t.FTP_Pwd & a & t.Cliente & a & t.Fornitore & a & t.EsenteEPAP & a & t.RisorsaInterna & a & t.wMail & "')"
                cmd_MC.ExecuteNonQuery()
            Else
                Dim sql_MC As String = "INSERT INTO Tab_Contatti (Cognome, Societą, wIndirizzo, wCAP, wCittą, wProvincia, Accesso_FTP_Arcadia, FTP_User, FTP_Pwd,Cliente,Fornitore,EsenteEPAP,Risorsa_Interna, wMail) VALUES ('"
                sql_MC &= t.Societą & a & t.Societą & a & t.wIndirizzo & a & t.wCap & a & t.wCittą & a & t.wProvincia & a & t.FTP & a & t.FTP_User & a & t.FTP_Pwd & a & t.Cliente & a & t.Fornitore & a & t.EsenteEPAP & a & t.RisorsaInterna & a & t.wMail & "')"
            End If
            Cn.Close()
But I can't develop the UPDATE routine
Can someone help me?
tnx
/r
Fatty
Re: Connection with Ms Access
« Reply #1 on: July 04, 2007, 12:18:03 PM »
Hi
I am not tested this query but
logically you no needed to write separate
sub for that, use your PUT sub
Just change INSERT clause in SQLstring on
something like this
Dim sql_MC As String = "UPDATE Tab_Contatti SET Fornitore = "SomeValue" WHERE wMail = & a & "someone@gmail.com" & a &
SET next field = another one ETC
~'J'~
Ricky_76
« Reply #2 on: July 04, 2007, 05:31:20 PM »
OK, tnx it works!!!!!!!
 :wink:
        Cn.Open()
        Dim sql_MC As String = "UPDATE Tab_Protocollo set Tipo_Missiva= 'HELLO' Where Codice_Commessa= '07_19_AI'"
        Cn.Close()
Fatty
« Reply #3 on: July 05, 2007, 04:14:51 AM »
Glad if that helps,
Btw, did you get my message?
Check you post please,
~'J'~
Ricky_76
« Reply #4 on: July 06, 2007, 09:39:17 AM »
Hi Fatty,
which one?? I read your response, that help me!
thank's again
/r
Fatty
« Reply #5 on: July 06, 2007, 02:09:41 PM »
I've send a manual on your address
Hth
~'J'~
