Code Red => .NET => Topic started by: UWPMVG on October 05, 2012, 05:03:12 AM
Is it possible to create a QuickProfile in Civil3D 2012 using .NET?
I have searched the internet and not found anything about QuickProfile.
In the API reference guide I found "SettingsCmdCreateQuickProfile" but did not understand how to use that information.
http://docs.autodesk.com/CIV3D/2013/ENU/API_Reference_Guide/html/a8aa4925-aa63-d1cf-dfbe-44bd04ffd238.htm (http://docs.autodesk.com/CIV3D/2013/ENU/API_Reference_Guide/html/a8aa4925-aa63-d1cf-dfbe-44bd04ffd238.htm)
Please anyone!?
SettingsCmd.... refers to settings which can be set in the Settings Tab of the ToolSpace.
I don't know if you can create a QuickProfile with .Net, but you can create a Surface Profile from a Surface. Why not simulate the Quick Profile with an app that creates a real Profile?
An example of such an app (which I made): http://www.youtube.com/watch?v=o3y1hoJCtog
Interesting approach! I'm going to try the same strategy.
Would it be possible to obtain a copy from part of your code? I fully understand if you donīt want to.
Thanks for your reply!
It is commercial software, you could buy it :-)
I have now programmed a similar app but I need to be able to update starting and ending point of the fixed line in the alignment using vb.net.
Does anyone know how that is accomplished?
I tried using "MoveGripPointsAt" but did not managed.
could you show the code to explain what you are try to do?
I have a short sample to create profile from surface.
This is not so secret code... 8-)
Cheers
Veli V.
Public Function CreateProfileFromSurface(ByVal alignName As String, _
ByVal surfaceName As String, _
ByVal profileName As String, _
ByVal profileStyleName As String, _
ByVal layerName As String) As AeccProfile
Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim oProfile As AeccProfile
Dim oAlign As AeccAlignment = Me.GetAlignment(alignName)
If oAlign.Name = alignName Then
Try
oProfile = oAlign.Profiles.Item(profileName)
Catch exArg As ArgumentException
Debug.WriteLine("Couldnīt find profile " + profileName)
End Try
If oProfile Is Nothing Then
Dim oProfileStyle As AeccProfileStyle = Me.GetOrCreateProfileStyle(profileStyleName)
Dim oSurface As IAeccSurface = Me.GetSurfaceByName(surfaceName)
If oSurface.Name = surfaceName Then
oProfile = oAlign.Profiles.AddFromSurface(profileName, AeccProfileType.aeccExistingGround, oProfileStyle.Name, oSurface.Name, oAlign.StartingStation, oAlign.EndingStation, layerName)
Else
ed.WriteMessage(vbLf + "Surface " + surfaceName + " doesnīt exist.")
End If
Else
ed.WriteMessage(vbLf + "Profile " + profileName + " already exist.")
End If
End If
Return oProfile
End Function
I want to change the coordinates of previous added fixed line. The Alignment only consists of one fixed line. I donīt want to erase the entity first and then create a new one.
Dim oAlignmentId As ObjectId = ObjectId.Null
Try
oAlignmentId = Alignment.Create(m_doc, "SectionViewer", "Site 1", "0", "Linjeberäkning - utskrift", "Visa inte - etiketter")
Catch ex As System.Exception
ed.WriteMessage(ex.Message + Convert.ToChar(10))
Return
End Try
If (oAlignmentId.IsNull) Then
ed.WriteMessage("Sample Alignment: Error creating alignment: " & Err.Description & " - " & Err.Number & Convert.ToChar(10))
Return
End If
sectionAlignment = trans.GetObject(oAlignmentId, AcDb2.OpenMode.ForWrite)
Dim point1 As Point3d = New Point3d(start_easting, start_northing, 0.0)
Dim point2 As Point3d = New Point3d(end_easting, end_northing, 0.0)Try
Dim oAlignmentTangent As AlignmentLine
oAlignmentTangent = sectionAlignment.Entities.AddFixedLine(point1, point2)
Return
End Try
I have no other solution to do that. This example using COM API.
vertexes have the points that are going to change for alignment.
If you find other solution I like to hear that too. :-D
vertexes = New Point3dCollection(...) 'Init points to this collection
Dim count As Integer = 0
Dim i As Integer = 0
Dim pt1, pt2 As Point3d
Dim strStat As Double = oAlignment.StartingStation
Dim endStat As Double = oAlignment.EndingStation
oAlignment.Entities.RemoveAll()
pt1 = vertexes(i)
count = vertexes.Count
For i = 1 To count - 1
pt2 = vertexes(i)
oAlignment.Entities.AddFixedLine1(pt1.ToArray(), pt2.ToArray())
pt1 = pt2
Next
oAlignment.Update()
