Author Topic: anyone master the customizing of the cui?  (Read 1898 times)
andrew_nao
« on: October 13, 2008, 09:46:11 AM »
what im looking to do is learn how to get the ribbon to change to another ribbon panel when in a specific command is activated.
for instance, when you go into block edit (bedit) you get an extra tab on the ribbon with just the block edit commands anyone know how to do this?
Crank
Re: anyone master the customizing of the cui?
« Reply #1 on: October 13, 2008, 04:46:59 PM »
There is no API available for the Ribbon, so that can't be done.
Spike Wilbury
« Reply #2 on: October 13, 2008, 06:18:32 PM »
i have no idea - i'm still in a2007 - but have the a2009 objectarx sdk and in the docs what's new they have:
Autodesk.AutoCAD.Ribbon Namespace
maybe?
Crank
« Reply #3 on: October 14, 2008, 02:23:04 AM »
In arx it's possible: I've seen a demo of Tony T. somewhere.
But there is nothing for lisp or vba.
Notsober
« Reply #4 on: October 17, 2008, 09:44:35 AM »
man, I thought the title was a legitimate question... one that required answering.
GhostRider
« Reply #5 on: October 24, 2008, 10:29:42 PM »
I thought so also...
menu's and palettes can be changed with commands but not the ribbon? I knew that thing was useless!!
