Thanks for your reply
1. An example whith the block "test"
(vla-put-explodable (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) "test") :vlax-false)
And i saved it in my hard drive (_.wbloc)
2. In a new drawing, I just do.
(defun Ouvrir_dessin_dbx(dwg / dbx)
(if (< (atoi (substr (getvar "ACADVER") 1 2)) 16)
(setq dbx (vlax-create-object "ObjectDBX.AxDbDocument"))
(setq dbx (vlax-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))))
(vla-open dbx dwg)
dbx
(setq dbx (Ouvrir_dessin_dbx "c:/temp/test.dwg"))
And i don't find where is information about explodable.
