Author Topic: the Swamp Block Library Manager?  (Read 62045 times)
Hugo
Re: the Swamp Block Library Manager?
« Reply #75 on: February 19, 2010, 05:17:48 AM »
Hallo jbuzbe
Ein Vorgabe von Layer und Skalierung wäre noch eine Tolle sache.
sonst super Super.
One target of scaling layer and would be even sache a madwoman.
otherwise super super.
Danke
jbuzbee
« Reply #76 on: February 19, 2010, 08:25:51 AM »
Thanks Hugo, glad you like it.  I'm going to work on the tree performance issue.
Kerry, I added the form definition to your lisp file so you won't have to load the odcl file seperately.  That'a a nice little feature Owen added.  Really cleans up deployment!
James Buzbee
Windows 8
pkohut
« Reply #77 on: February 19, 2010, 10:33:52 AM »
Possible speed ups - Looking at the source code and the picture at this link
http://www.theswamp.org/index.php?topic=32081.msg377241#msg377241
I think you can get rid of the file modification dates and sizes without loosing functionality, as it's just visual noise. 1) For those rare occasions when a user wants the info they can get it by other means.  2) The code to retrieve and format the display info is fairly involved. 3) How efficient are vl-file-size and vl-file-systime?  Do they do a file open and close for each operation (don't know)? If they do then this can be a very expensive operation, and more so over a network.
Having not run the application or knowing anything about OpenDCL and such, I can only guess that the directory tree is being fully populated at startup.  If this is the case then you will get a huge performance boost by only retrieving directories/sub directories info when needed, ie. by expanding a sub directory leaf.
t-bear
« Reply #78 on: February 19, 2010, 11:43:58 AM »
OK...minor problem.  This keeps resetting ATTREQ and FILEDIA to "0".   :roll:
« Reply #79 on: February 19, 2010, 03:41:57 PM »
Yes James I know about the ability to add the ASCII dialog to .LSP source. I don't do it for developments or sample code .
For anyone who wants to use this I remind you that Post #21 has the attachments for the supporting Library File and .INI Configutation File and ALSO  the Source .ODCL file if you want to make changes to the dialog.
Also note Reply #56 : the changes I've noted in that post should be made if your attributes are NOT preset and require confirmation .
I'll call this Build _08 since _07 has been used.
« Last Edit: February 19, 2010, 03:45:10 PM by Kerry Brown »
jbuzbee
« Reply #80 on: February 19, 2010, 04:11:15 PM »
Which one tbear, mine or Kerry's?  Mine shouldn't set any variables at all.
This is why hijacks are so problematic . . ..
James Buzbee
Windows 8
« Reply #81 on: February 19, 2010, 04:23:48 PM »
Well that's not mine :)
Any changes I make I restore, even after errors
... and I don't set ATTREQ and FILEDIA to "0".
« Reply #82 on: February 19, 2010, 06:07:54 PM »
I smell a command call.  he he he :evil:
« Reply #83 on: February 19, 2010, 06:27:53 PM »
When you use the command to insert a block with attributes you must address the following system variables.
ATTDIA
Controls whether the -INSERT command uses a dialog box for attribute value entry. See "INSERT Command Line."
0        Issues prompts on the command line
1        Uses a dialog box
ATTMODE
Controls display of attributes.
0        Off: Makes all attributes invisible
1        Normal: Retains current visibility of each attribute: visible attributes are
                displayed; invisible attributes are not
2        On: Makes all attributes visible
ATTREQ
Determines whether the INSERT command uses default attribute settings during insertion of blocks.
0        Assumes the defaults for the values of all attributes
1        Turns on prompts or dialog box for attribute values, as specified by ATTDIA
TEXTEVAL
Controls the method of evaluation of text strings.
0        All responses to prompts for text strings and attribute values are taken literally
1        Text starting with an opening parenthesis [ ( ] or an exclamation mark (!) is
            evaluated as an AutoLISP expression, as for nontextual input
(setq sysattdia (getvar "ATTDIA"))
(setq sysattreq (getvar "ATTREQ"))
(setq systxteva (getvar "TEXTEVAL"))
(setvar "ATTDIA" 0)
(setvar "ATTREQ" 0)
(setvar "TEXTEVAL" 0)
<do your lisp>
(setvar "ATTDIA"   sysattdia)
(setvar "ATTREQ"   sysattreq)
(setvar "TEXTEVAL" systxteva)
Alternately you can use the sys var EXPERT
EXPERT
Type: Integer
Not saved
Initial value: 0
Controls whether certain prompts are issued.
0 Issues all prompts normally.
1 Suppresses "About to regen, proceed?" and "Really want to turn the current layer off?"
2 Suppresses the preceding prompts and "Block already defined. Redefine it?" (BLOCK) and "A drawing with this name already exists. Overwrite it?" (SAVE or WBLOCK).
3 Suppresses the preceding prompts and those issued by the LINETYPE command if you try to load a linetype that's already loaded or create a new linetype in a file that already defines that linetype.
4 Suppresses the preceding prompts and those issued by UCS Save and VPORTS Save if the name you supply already exists.
5 Suppresses the prompt, "That name is already in Use, redefine it?" issued by the -DIMSTYLE Save option when you supply the name of an existing dimension style.
When a prompt is suppressed by EXPERT, the operation in question is performed as
though you  entered y  at the  prompt. Setting  EXPERT can  affect scripts, menu
macros, AutoLISP, and the command functions.
« Reply #84 on: February 19, 2010, 06:38:13 PM »
As can be seen from post  Reply #56
(acet-error-init (list (list "CMDECHO"   0
                                "expert"    5              ;;<<==
                                "ATTREQ"    1            ;;<<==
                                "ATTDIA"    1             ;;<<==
                                "BLIPMODE"  0
                                "INSUNITS"  0
                                "OSMODE"    0
                                "PICKADD"   1
                                "PICKBOX"   5
                                "SNAPANG"   0
                                "SNAPMODE"  0
                                "SORTENTS"  1
                          0
The variables noted are stored, changed to the value nominated for the duration of the routine and the previous values are restored on termination or error.
I don't set either ATTREQ or FILEDIA to "0".
« Reply #85 on: February 19, 2010, 06:48:59 PM »
That a slick trick Kerry, haven't been following this thread much so I missed #56.  :-)
« Reply #86 on: February 19, 2010, 06:59:53 PM »
Yes, I like the idea.
I have my own custom routines for that and error trapping routines ... but chose not to post them, so used the ExpressTools routines instead.
added:
if you add
"CLAYER"(getvar "CLAYER")
or
something like "CLAYER" "MySpecialTextLayer"
to the list any layer changes during the procedure will nullified at termination when CLAYER is reset to the initial value
« Last Edit: February 19, 2010, 07:03:45 PM by Kerry Brown »
t-bear
« Reply #87 on: February 22, 2010, 09:14:28 AM »
I am using what I believe is jbuzbee's original build....might be the problem.  I kinda got lost with all the builds ans stuff.  Will have to hunt up the latest installment of this and try again.
jbuzbee
« Reply #88 on: February 22, 2010, 04:33:18 PM »
The latest is in the original post - I finaaly figured out how to fully edit a post  :-P
I'm still working on the whole tree thing . . . could use some help.
James Buzbee
Windows 8
t-bear
« Reply #89 on: February 23, 2010, 08:51:01 AM »
Thanks amigo, I'll reload it.
As far as helping you with this, you might have noticed....I'm worthless.....sorry.  :cry: :|
