Hello guys,
Currently I'm checking a bunch of drawings if they meet some criteria. Our engineers have to draw a single drawing frame around construction elements and a single drawing table on each layout.
The drawing table has to be inside the drawing frame. Basically I have to check if extents of the drawing table (a block reference) is inside the extents of the drawing frame (another block reference).
As you can see on the attached picture, with purple color, the extents returned by ACAD are wider than the graphical representation of the drawing table and they reach outside the frame. My routine count this drawing as wrong, but it is actually not. How I could overcome this, could you help me, please!
You can find the drawing attached below. I'm using mgddbg tool for dumb the extents.
Best regards, Angel!
