Bursting a previously inserted block?
AVCAD:
Is there away to burst a block right after you insert it. The Select previous command doesn't work very well and usually selects the object you had selected before you inserted the block.
I am sure there is just a function I don't know.
I am on ACAD 2006.
Thanks in advance.
AVCAD:
just a side question cause I am working on something right now with fields.....
Fieldeval = 31
what is 31????
I know there are
0 - not updated
1 - update on open
2 - update on save
4 - update on plot
8 - update on etransmit
16 - updated on regen
but there is no definition for 31 and thats the default value of that variable
thanks again.
LE:
(+ 0 1 2 4 8 16) = ?
AVCAD:
--- Quote from: Luis Esquivel on October 09, 2007, 10:55:30 AM ---(+ 0 1 2 4 8 16) = ?
--- End quote ---
OWNED BY LOGIC.... :ugly:
LE:
--- Quote from: AVCAD on October 09, 2007, 10:50:20 AM ---Is there away to burst a block right after you insert it. The Select previous command doesn't work very well and usually selects the object you had selected before you inserted the block.
I am on ACAD 2006.
Thanks in advance.
--- End quote ---
Use 'Last'
--- Quote ---Command: burst
Select objects: L
1 found
Select objects:
--- End quote ---
Navigation
[0] Message Index
[#] Next page
Go to full version
