Author Topic: how to add a printer for cad by using lisp program?  (Read 1955 times)
taner
« on: March 11, 2008, 12:58:27 AM »
Dear all
tks
Patrick_35
Re: how to add a printer for cad by using lisp program?
« Reply #1 on: March 11, 2008, 08:39:23 AM »
Hi
An example
(setq wsn (vlax-create-object "WScript.Network"))
(vlax-invoke wsn 'AddWindowsPrinterConnection "\\\\Server_name\\Printer_name")
(vlax-release-object wsn)
« Reply #2 on: March 11, 2008, 09:44:36 AM »
Be sure to add (vl-load-com) any time use use vla vlax or vlr functions to load the ActiveX support.
You only need to call it once but you must call it for the functions to be available.
rkmcswain
« Reply #3 on: March 11, 2008, 01:27:53 PM »
Sort of a side-topic, but why doesn't Autodesk just remove that requirement and add the necessary libraries in the core program...? At the very least, they could add (vl-load-com) to acad200x.lsp
septicad
« Reply #4 on: March 19, 2008, 12:30:29 PM »
Is there a way to create a list of the currently installed printers in LISP - and then also determine their associated paper sizes?
To better understand my issue: See a quick movie demostration here of my DCL/LISP code: http://www.septicad.com/temp/sprint.html  [ignore the truetype issues with the latest Bricscad release].
Currently, the user has to physically enter the PrinterName and PaperName, which is cAseSensitIVe - (i.e. hp DeskJet xxx, Letter 8.5" x 11").  The variation in paper size naming from printer to printer is rediculous (Letter - vs - 8.5" x 11" letter size...  Of course the user only has to do this once (its stored in a text file for further use), but still... its a pain to answer these support calls if I don't need to...
Thanks in advance
Steve Marcotte
SeptiCAD.com
