Author Topic: QuickCalc, CAL or ...  (Read 5289 times)
TimSpangler
  • CAD Naked!!
Re: QuickCalc, CAL or ...
« Reply #15 on: August 15, 2008, 12:30:47 PM »
I use 'cal alot. Never had any trouble with it.
ACA 2015 - Windows 7 Pro
Kate M
« Reply #16 on: August 15, 2008, 12:32:14 PM »
Kate, is QuickCalc in LT? If so that might make for a good read on your blog. :-)
It is indeed, and although I've posted on how to open & close it, I haven't posted yet on how to use it. Good idea. :-)
Did you know you can set variables in QuickCalc by simply entering '$var=20'. And recall the variable using '$var+100'.
Is this different from the stuff you can store in the Variables pane?
« Reply #17 on: August 15, 2008, 12:50:47 PM »
No, they are the same.
« Reply #18 on: August 18, 2008, 03:22:06 PM »
Kate M
« Reply #19 on: August 18, 2008, 06:43:39 PM »
And I just found out today that we have CAL too! Woot! There's been a command line calculator in LT since 2006...and I never knew. :ugly: Of course, I just use the palette. :-)
