Hello,
I am not sure, but have doubts that some of my recent lisps are causing this bug.
Some duplicate layers started to upper in my files. This can happen 1-2 times a day, but I cannot track which operation is causing this.
Duplicate layers start with real layer's name + @8, @48, ... See attached screenshot.
At the same time some objects that are affected show no layer at all in properties (blank). After merging layers and running audit $AUDIT-BAD-LAYER is created with problematic objects on it.
All of the affected objects are dynamic blocks (annotative).
I assumed this is due to a corrupted file, but other files also started to do the same.
I used an object reactor recently + reactor for layers from Lee Mac.
Also some of lisp that we use change layers sometimes.
Anybody seen this kind of behavior before? Might any lisp cause that?
