Author Topic: How to find vertex number  (Read 9326 times)
matrix2005in
« on: June 03, 2006, 11:18:04 PM »
any lisp for finding vertex number and give the vertex number you selected...
any ideas??
« Last Edit: June 05, 2006, 04:39:38 PM by CAB »
ElpanovEvgeniy
  • Moscow (Russia)
Re: HOw to find vertex number
« Reply #1 on: June 04, 2006, 04:09:13 AM »
any ideas??
Choice of a segment in a polyline the instruction of a point...
http://www.theswamp.org/index.php?topic=8878.msg114384#msg114384
« Reply #2 on: June 04, 2006, 09:06:27 AM »
(defun c:test ()
  ;;  no error checking
  (setq esel (entsel "\nSelect a pline"))
  (setq ent (car esel))
  ;;  get exact point ON the pline
  (setq pt (vlax-curve-getclosestpointto ent (cadr esel)))
  ;;  Get vertex number, if point is not exactly on a verted the number
  ;;  returned will have the fractional position relivitive to the previous vertex
  (setq par (vlax-curve-getparamatpoint ent pt))
  ;;  get closest vertex number
  (if (> (rem par 1) 0.5)
    (setq vertex# (1+ (fix par)))
    (setq vertex# (fix par))
  (prompt (strcat "\nVertex Number = " (itoa vertex#) ", note that 0 if the first vertex."))
qjchen
  • Best wishes to all
« Reply #3 on: June 04, 2006, 09:43:00 PM »
hi:)
 I want to write a program to draw a pline with arrow at the end.
That is, when I draw a pline, then it automatic change the last segment to an arrowlike shape. (different width at the last segment).
So I should draw the pline first, then modify the pline. First  add one vertex at the last segment, second change the new maked segment width to W (a constant value) ->0.
But I am not familiar with pline operation, could you help me? :)
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
matrix2005in
« Reply #4 on: June 05, 2006, 09:45:17 AM »
hi cab
thanks for your code...
actually your code was near to what i was looking...so i changed your code little bit and now i am getting proper vertex number....thanks once again..
(defun c:test ()
  (if (> (rem par 1) 0.0)
      (= vertex# 0)
      (setq vertex# 1)
  (itoa vertex#)
« Reply #5 on: June 05, 2006, 10:15:49 AM »
matrix2005in
If you want the vertex number to start at 1 you will need to increment all vertex returned,
not just the first one. Use this:
(defun c:test ()
  (setq vertex# (1+ vertex#))
  (prompt (strcat "\nVertex Number = " (itoa vertex#)))
matrix2005in
« Reply #6 on: June 05, 2006, 10:35:27 AM »
CAB i was tried the same way too..it was not giving proper result..
but if you try the one which i modyfied you know the dfference..
thanks
mathew
matrix2005in
« Reply #7 on: June 05, 2006, 10:44:02 AM »
HI CAB i am just a beginner of lisp...
i was testing with your lisp, changed some part just like that to see the result and it works fine...
 i just set it up first vertex is =1
but my confusion is the rest of the vertex numbers are correct with respect to the first one..
How come?????????
« Reply #8 on: June 05, 2006, 12:25:08 PM »
matrix2005in
The results are as follows:
Actual Vertex Number, first lisp returns
0 1 2 3 4 ...
Your routine returns
1 1 2 3 4 ....
It should return and my second code does return
1 2 3 4 5 ....
« Reply #9 on: June 05, 2006, 01:09:29 PM »
hi:)
Here is a quick and easy way to approach your request.
This should give you some ideas you can work with.
(defun c:test ()
  (prompt "\nDraw your pline.")
  (command "PLINE")
  (while (> (getvar "CMDACTIVE") 0)
     (command pause)
  (setq ent (entlast))
  (setq ArrowLength 5
        ArrowWidth  2
  (setq ArrowBasePt (vlax-curve-getPointAtDist ent ArrowLength))
  (command "_pedit" ent "_e" "_i" "_non" ArrowBasePt "_x" "_e" "_w" "0" ArrowWidth "_x" "" "")
matrix2005in
« Reply #10 on: June 05, 2006, 02:42:35 PM »
My code is also returning same..
1,2,3,4...
can you check it..i checked in multiple versions and machines...
results are same...
mathew
« Reply #11 on: June 05, 2006, 04:37:52 PM »
matrix2005in
Here is the result of my test.
The vertext number is placed at the pick point.
Try each one on your drawing.
(defun c:yours ()
      ((= vertex# 0)
      (setq vertex# 1))
  ;;  Debug On ===================================================
  (setq txt (itoa vertex#))
  ;; If text height is undefined (signified by 0 in the table)
  (if (= (cdr(assoc 40(tblsearch "style" (getvar "textstyle")))) 0)
    (command "_text" "_mc" "_non" (cadr esel) "" 0 txt)
    (command "_text" "_mc" "_non" (cadr esel) 0 txt)
  ) ; endif
(defun c:mine ()
  ) ; endif
« Last Edit: June 05, 2006, 04:48:21 PM by CAB »
Re: How to find vertex number
« Reply #12 on: June 05, 2006, 04:49:04 PM »
matrix2005in
I just realized you cond statement is incorrect
      (= vertex# 0)
      (setq vertex# 1)
Sould be written like this:
      ((= vertex# 0)
      (setq vertex# 1))
I fixed the one above in the 'yours' code example.
Joe Burke
« Reply #13 on: June 06, 2006, 10:58:06 AM »
CAB,
Just a thought regarding this:
  ;; always trans the entsel point to WCS
  (setq pt (vlax-curve-getclosestpointto ent (trans (cadr esel) 1 0)))
« Reply #14 on: June 06, 2006, 01:08:19 PM »
Good point Joe. <no pun intended> :-)
