Is this the first time you have done this process ? If so, it is more likely to be a procedural error.
Exactly how are you doing it ?
I assume the program runs prior to compiling ?
Are you using Separate namespace ?
You may need to provide snapshots of your dialogs.
Regards,
added
Does your compile statement look something like this
(vlisp-compile
'st
"L:/Projects-VisualLisp-2017/SD210/Tools/KDUB_NewUcs.lsp"
"L:/Projects-VisualLisp-2017/FAS/KDUB_NewUcs"
