Code Red => Visual DCL Programming => AutoLISP (Vanilla / Visual) => OpenDCL => Topic started by: Kerry on August 30, 2008, 10:11:29 PM
http://otb.manusoft.com/2008/08/opendcl-quick-intro.htm
If you're an AutoLISP programmer, you've probably heard about OpenDCL. Maybe you've even checked it out, but it looked complicated and you weren't sure whether it was worth the trouble to learn how to use it. Either way, do yourself a favor and spend 10 minutes to go through the following 10-step quick introduction to OpenDCL.
<snip>
