Author Topic: Modifying Lee Mac's PolyTools "PJ" routine without success.  (Read 2752 times)
jlogan02
« on: August 26, 2022, 01:23:21 PM »
Trying to use Lee Mac's PJ routine by changing the selection to a crossing window
to eliminate user input.
Getting a syntax error.
I also need to verify that the lines I'm selecting aren't already polylines.
  1. (defun c:pj ( / *error* bl1 bl2 bl3 bl4 sel1 sel2 val var )
  2.
  3.     (defun *error* ( msg )
  4.         (mapcar '(lambda ( a b ) (if b (setvar a b))) var val)
  5.         ;;(LM:endundo (LM:acdoc))
  6.         (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
  7.             (princ (strcat "\nError: " msg))
  8.         )
  9.         (princ)
  10.     )
  11.
  12.   (if
  13.
  14.     (setq
  15.       bl1 '(0.0 0.0)  ;;lower left white border corner
  16.             bl2 '(-1.0 -1.0)
  17.       bl3 '(34.00 22.00)  ;;Upper Right white border corner
  18.             bl4 '(34.0625 22.0625)
  19.     )
  20.
  21.     (setq dim (getvar 'dimscale)
  22.       bl1 (mapcar '* bl1 (list dim dim))
  23.             bl2 (mapcar '* bl2 (list dim dim))
  24.             bl3 (mapcar '* bl3 (list dim dim))
  25.             bl4 (mapcar '* bl4 (list dim dim))
  26.   )
  27.
  28.     (setq sel1 (list (car bl1) (cadr bl2)))
  29.     (setq sel2 (list (car bl3) (cadr bl4)))
  30.
  31.         (progn
  32.             (setq var '(cmdecho peditaccept)
  33.                   val  (mapcar 'getvar var)
  34.             )
  35.             (mapcar '(lambda ( a b c ) (if a (setvar b c))) val var '(0 1))
  36.             (command "_.pedit" "_m" sel1 sel2 "" "_j" "" "")
  37.         )
  38.   )
  39.
  40.     (*error* nil)
  41.     (princ)
  42. )
  43. ;; ssget  -  Lee Mac
  44. ;; A wrapper for the ssget function to permit the use of a custom selection prompt
  45. ;; msg - [str] selection prompt
  46. ;; arg - [lst] list of ssget arguments
  47.
  48. (defun LM:ssget ( msg arg / sel )
  49.     (princ msg)
  50.     (setvar 'nomutt 1)
  51.     (setq sel (vl-catch-all-apply 'ssget arg))
  52.     (setvar 'nomutt 0)
  53.     (if (not (vl-catch-all-error-p sel)) sel)
  54. )
  55.
  56. ;; Start Undo  -  Lee Mac
  57. ;; Opens an Undo Group.
  58.
  59. (defun LM:startundo ( doc )
  60.     (LM:endundo doc)
  61.     (vla-startundomark doc)
  62. )
  63.
  64. ;; End Undo  -  Lee Mac
  65. ;; Closes an Undo Group.
  66.
  67. (defun LM:endundo ( doc )
  68.     (while (= 8 (logand 8 (getvar 'undoctl)))
  69.         (vla-endundomark doc)
  70.     )
  71. )
  72.
  73. ;; Active Document  -  Lee Mac
  74. ;; Returns the VLA Active Document Object
  75.
  76. (defun LM:acdoc nil
  77.     (LM:acdoc)
  78. )
  79.
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
ribarm
  • Marko Ribar, architect
Re: Modifying Lee Mac's PolyTools "PJ" routine without success.
« Reply #1 on: August 26, 2022, 02:39:47 PM »
Perhaps, untested, though...
(command "_.pedit" "_m" (LM:ssget "SELECTED..." (list "_W" sel1 sel2)) "" "_j" "" "")
M.R. on Youtube
« Reply #2 on: August 26, 2022, 03:18:38 PM »
Perhaps try something along the lines of the following:
  1. ;; Polyline Join  -  Lee Mac
  2. ;; Attempts to join all lines, arcs and polylines in a selection.
  3.
  4. (defun c:pj ( / *error* dim sel val var )
  5.
  6.     (defun *error* ( msg )
  7.         (mapcar '(lambda ( a b ) (if b (setvar a b))) var val)
  8.         (LM:endundo (LM:acdoc))
  9.         (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
  10.             (princ (strcat "\nError: " msg))
  11.         )
  12.         (princ)
  13.     )
  14.
  15.     (setq dim (getvar 'dimscale))
  16.     (LM:startundo (LM:acdoc))
  17.     (if
  18.         (setq sel
  19.             (ssget "_C"
  20.                 (mapcar '* (list dim dim) '(34.0 22.0625))
  21.                 (mapcar '* (list dim dim) '( 0.0 -1.0000))
  22.                '(
  23.                     (-4 . "<OR")
  24.                          (0 . "LINE,ARC")
  25.                          (-4 . "<AND")
  26.                              (0 . "LWPOLYLINE")
  27.                              (-4 . "<NOT")
  28.                                  (-4 . "&=") (70 . 1)
  29.                              (-4 . "NOT>")
  30.                          (-4 . "AND>")
  31.                      (-4 . "OR>")
  32.                 )
  33.             )
  34.         )
  35.         (progn
  36.             (setq var '(cmdecho peditaccept)
  37.                   val  (mapcar 'getvar var)
  38.             )
  39.             (mapcar '(lambda ( a b c ) (if a (setvar b c))) val var '(0 1))
  40.             (command "_.pedit" "_m" sel "" "_j" "" "")
  41.         )
  42.     )
  43.     (*error* nil)
  44.     (princ)
  45. )
  46.
  47. ;; Start Undo  -  Lee Mac
  48. ;; Opens an Undo Group.
  49.
  50. (defun LM:startundo ( doc )
  51.     (LM:endundo doc)
  52.     (vla-startundomark doc)
  53. )
  54.
  55. ;; End Undo  -  Lee Mac
  56. ;; Closes an Undo Group.
  57.
  58. (defun LM:endundo ( doc )
  59.     (while (= 8 (logand 8 (getvar 'undoctl)))
  60.         (vla-endundomark doc)
  61.     )
  62. )
  63.
  64. ;; Active Document  -  Lee Mac
  65. ;; Returns the VLA Active Document Object
  66.
  67. (defun LM:acdoc nil
  68.     (LM:acdoc)
  69. )
« Reply #3 on: August 26, 2022, 04:35:48 PM »
Aren't lines 35-39--and 7--a bit obfuscated? I mean, I feel this should be moved to a separate procedure call to clarify what is happening (-i.e. make more readable). I have this in one of my lib routines.
  1. (defun #Error_Push_Vars ( lst / push->lst)
  2.   ;; This procedure will generate a list of
  3.   ;; variables and their orig. value before
  4.   ;; changing them to a desired value
  5.   ;;
  6.   ;; By: John K
  7.   ;;     11.28.06
  8.   ;;
  9.   ;; Example Use: (#Error_Push_Vars
  10.   ;;                  '(("CMDECHO" 0) ("BLIPMODE" 1)
  11.   ;;                    ("SNAPANG" 45) ("OSMODE" 0)))
  12.   ;;
  13.   ;; The syntax of the list members is as follows:
  14.   ;;  ( <Variable name to change/save>  <setting desired> )
  15.   ;;
  16.   ;; The variables orig value will be saved for later
  17.   ;; restoration.
  18.   ;;
  19.   ;;
  20.   ;; Note: This procedure is part of the
  21.   ;;       an ERROR trap set of procedures.
  22.   ;;
  23.   (defun push->lst (sym lst)
  24.     (set lst (cons sym (eval lst))) )
  25.   (mapcar
  26.     '(lambda (x)
  27.        (push->lst (list 'setvar (car x) (getvar (car x))) '#Error_Lst#)
  28.        (if (cadr x)
  29.          (setvar (car x) (cadr x)))
  30.        )
  31.     lst
  32.     )
  33.   )
  34.
Which would then also make line 7 become: (mapcar 'eval #Error_Lst#)
« Reply #4 on: August 26, 2022, 04:56:58 PM »
FWIW, I find mine more readable; also, what if the system variable isn't available in the version in which your function is evaluated?
« Reply #5 on: August 26, 2022, 05:19:54 PM »
The problem is that people will obviously copy paste code without understanding it so, *you* may find it more readable but *someone else* may not with out proper understanding; I was speaking more towards the black-box methodology.
It will error out, of course. -i.e. I understand yours will generate a nil list but which is worse for a programmer that may never notice they misspelled a variable: 1. blindly (re)set values assuming all is well or 2. code errors out upon load/run?
Command: (#Error_Push_Vars '(("CDECHO" 0)))
; error: AutoCAD variable setting rejected: "CDECHO" 0
Command: (setq var '(cdecho)
(_>       val  (mapcar 'getvar var))
(nil)
« Reply #6 on: August 26, 2022, 06:01:54 PM »
A programmer mispelling a variable is just bad code; my point is that not all system variables are available in all versions of AutoCAD or on all platforms supporting a LISP API, hence if code is to be compatible across a wide range of releases, such differences need to be accounted for to avoid errors. For example, I believe the PEDITACCEPT system variable was introduced in 2004, so earlier versions would result in an error.
« Reply #7 on: August 27, 2022, 10:00:34 AM »
Misspellings are a great portion of the compiler’s complainants about my code (but jokes aside). Precisely my point. Code should be maintained; if the procedure or developer needs a variable which isn’t available the rule is to “fail fast” because these errors are typically easier to find and fix.
« Reply #8 on: August 29, 2022, 08:21:43 AM »
...if the procedure or developer needs a variable which isn’t available the rule is to “fail fast” because these errors are typically easier to find and fix.
This means that the code would only be compatible with a small range of releases, erroring in others.
rkmcswain
« Reply #9 on: August 29, 2022, 09:00:05 AM »
Quote from: Lee Mac
....my point is that not all system variables are available in all versions of AutoCAD or on all platforms supporting a LISP API, hence if code is to be compatible across a wide range of releases, such differences need to be accounted for to avoid errors.
Just wanted to "like" this.  :angel:
« Reply #10 on: August 29, 2022, 09:46:03 AM »
I don't think I understand the argument; if the code needs a variable--and it's not available--you want it to continue until after you've changed the end-user's environment?
If the variable is not actually required -i.e. the code can run without it- why would you add it in the first place?
Tharwat
  • Hypersensitive
« Reply #11 on: August 29, 2022, 10:54:13 AM »
If a variable ( that retrieved from sys_var ) has a value, then that means the system variable is available then set the new desired value otherwise ignore the setting and resetting on exit.
« Reply #12 on: August 29, 2022, 12:09:44 PM »
Right. But again, if your code can operate without that variable then why set/reset it in the first place?
Tharwat
  • Hypersensitive
« Reply #13 on: August 29, 2022, 12:57:29 PM »
Of course there is a goal behind using system variables to perform a certain process and of course you have the choice to use it or to leave it behind.
So you can ignore the use of CMDECHO then the history statements of the command used will be printed on the command line so we need it for a better presentation and performance of codes in this case.
Suppose the CMDECHO was not supported into your AutoCAD release and we want to use it, then how to know without testing out the return value of that sys_var to decide to set then reset ? So the main point resides here.
« Reply #14 on: August 29, 2022, 01:18:22 PM »
Meh! I'm not sold; the code prohibits the use of current AutoCAD on MACs so it's not that big of an issue to limit the use of an 18+ year old AutoCAD release as well.
