Author Topic: Civil 3D - I Need TWO Sizes For My Labels  (Read 7255 times)
  • Custom Title
Re: Civil 3D - I Need TWO Sizes For My Labels
« Reply #15 on: September 03, 2006, 03:47:35 AM »
expect a post at Civil 3D.com by the sunday AM
That's awesome Dana. Thanks a bunch, I almost can't wait to return to work Tuesday just to try this. :-)
welcome to theswamp!
Jason Hickey
« Reply #16 on: September 03, 2006, 12:23:07 PM »
Parcel topology - what a B***H.   Autodesk, in their infinite wisdom, has given us one of the coolest tools since the "UNDO" button and no clear way to tell us how to make it work.
Creating a subdivision lot layout is a bit like building a 100 story building - if you don't start with a good foundation, your building is eventually going to come crashing down around you.   Start out with a GOOD boundary.   Clean it up with the Map Cleanup tool.   Pay attention to how your ROW is created.   A;ways remember - every lot line that is common with another should only have ONE LINE (or curve) defined for that common line!   Multiple lot lines stacked on top of each other will cause you to curse the existence of the ancestors of the development team in Manchester - trust me, I've been there.   But once that "topology" lightbulb went off over my head, I picked up on it and am USING it.   I've had similar lightbulbs regarding the CUI (hey, some of these weren't RECENT lightbulbs), Profile views, generic subassemblies, intersection design, and quite a few other things.    I've got a lightbulb or two about to come on as well - I can feel the electricity "humming."
While it's on my mind - MM, of COURSE you can label parcels twice, providing that you're using C3D 2007.   Ever heard of a general note with reference text?
dbreigprobert
« Reply #17 on: September 03, 2006, 12:58:38 PM »
the interesting thing is that truly "good topology" from the textbook definition (as applied to Map topologies and others) doesn't allow the span label to function.
Hence my original confusion.
In the strictest definition of good topology there are no overlapping lines at all- meaning each segment terminates at the node (or intersections)
So I think I have reverse engineeered enough of it that between jason and i we will write the blog post of the century soon.
Jason Hickey
« Reply #18 on: September 03, 2006, 05:08:48 PM »
Holy crap, thanks for that pressure.    That's one heckuva promise to have to live up to  ;-)
Cannon
« Reply #19 on: September 04, 2006, 08:30:41 AM »
BAH.
Good C3D topology will by its very nature be dirty in a GIS sense. You can't slide bearings if the line ends at the first concept plan lot line. ROW and Boundaries MUST be continuous to make labeling and closure sense. Performing a Map cleanup without thought on a site plan would destroy it for C3D use. Yes, you should get rid of Null nodes, overhangers, and little shorties. A GOOD surveyor will present you with clean topology. A good planner probably won't, they just don't care.
And I think most of you could avoid two label styles on one object. Parcels being the _one_ exception that I've found because of their Un-Vaultiness (is that a word? It is now.) The rest of the use cases preseted here for two label styles and the headaches there in can be handled by using data shortcuts.
Now back to the regular Nick, Jason and Dana show.  And the post of the Century? That's a big claim.
dbreigprobert
« Reply #20 on: September 04, 2006, 11:38:02 AM »
Ok, so if between you, me and jason we have this whole Civil3D topology thing licked, why arent we writing AOTC parcels right this second?  We need to before we give away all of our secrets.
Here is the deal on the data shortcuts.
Fine.  Cool.  Rework your entire workflow and the comapny workflow, i am all for tha.
But guys like Dinosaur are lone wolves.  The boss says- try it.  If you fail, its done. is over.  no room to shift that paradigm later.  These guys need a solution now.  Once they get in, they do a project, their eyes open and see possibilities.
Secondly, do you know how many phone calls, emails, requests and otherwise I get PER DAY about stuff like this?  people who are knee deep in projects.  People who are cadautl clients but maybe didnt get training.  or maybe got training but for some reason still went back into an old drawing and didnt move it forward to a Civil 3D template.
They are googling, questioning and calling because they need a solution now.  What am I supposed to tell them?  "Rework you workflow.  Install vault andstart over?"
No freaking way.
If i give them that line they will miss their deadline get pissed at me and autodesk, go back to land desktop and tell me later what a crock of crap civil 3d was cause they couldnt change their label size.
these are firms that current manage to sets of land desktop labeling or dtext anyway.  their layer states are already established (whether officially or "in their heads") to accomodate different text sizes in differnt plats.  or maybe they label in paperspace to avoid all confusion on scale all together.
THIS is what I am upagainst.  I can't hide from it and I won't say you cant use ciivl 3d if you dont change everything.  that's not gonna happen.
in my personal work, where i work over spotty VPNs, FTPs and other not so tight data sharing situations I would rather hand over a baseplan that can be xrefed into many sheet families and a CAD tech can just zip through and change layer states than try to wrestle with vault over distance.
So sure.  Ideally, and eventually, change your whole workflow.  But for now, who gives a crap?  Just label the damn line and get back to work.
And this is why the James, Nick, Jason and Dana show is so entertaining. Consider the can of worms opened.
Jason Hickey
« Reply #21 on: September 04, 2006, 01:00:05 PM »
James is right about a few things:
1) Map Cleanup is one of the most powerful (and dangerous) tools that I've ever seen.   Use it carefully, or it will **** up your drawing.
2) Surveyors almost always give me a boundary with passable topology.
3) Planners/project managers/people who lay out subdivisions for conceptual design almost always give me crap.   This is why I need Map Cleanup.
Now, I'm wondering a) if parcels will ever work with Vault, and b) why no one hasn't talked about general labels with reference text more in depth yet  ;-)
Dinosaur
« Reply #22 on: September 04, 2006, 01:06:02 PM »
I sure am a troublemaker, aren't I?
How about this for EVERYONE to chew on . . . Right now, my situation is not that critical.  My personal instructor has tried numerous times to get a training session in place, but they are adamant in their refusal to consider actually learning their own tools.  My powers that be have already pulled the plug on any new subdivision work being done with anything other than 2005 Land Desktop.  I can do some small siteplan work in 2006 Civil 3D as long as no one else has to touch it . . . if I am not at work and my C3D project needs something that can not wait, when I return it will be a LDT project and if there was ANY trouble converting it over I will be catching flack.  Further, if I tried to do it in 2007 I would be sent down the road kicking rocks.  Essentially I am now using it for evaluation purposes again, so if it were not for the 2007 thing I would be 100% up for ANY changes in workflow, methodology, standards or anything else that would get me moving forward again.  Any REAL evaluation I will be doing is own my own time on either a dummy or mirrored project.
PLEASE, what I need to know most is how to make this software sing . . . give me your collective best shots.
Dinosaur
« Reply #23 on: September 04, 2006, 02:45:20 PM »
. . . Now, I'm wondering a) if parcels will ever work with Vault, and b) why no one hasn't talked about general labels with reference text more in depth yet  ;-)
THIS is the real direction I have anticipated treveling.  I have never really liked the concept of dynamic updates for any plat labels.  I have found several instances where errors had crept into the geometry while in the process of reworking the affected labels which would have gone unnoticed without that check.  The lot geometry I am often given is complex to the point that even if spanning labels worked without all of the common workarounds I would have to give many lots their own site to have them labeled properly.  I wish I had a good example to post for this type of area, but non of my parcel segment labeling efforts have survived.  I think the only logical choice I will have will be to pick off the values and use general labels and reference text.
dbreigprobert
« Reply #24 on: September 04, 2006, 03:24:04 PM »
I didnt meant that to sound at all like I wanted to give James a hard time.  on the contrary.  James is my hero.  My mentor.  The man who has made so much come in to focus.  Seriously.
And I really WANT to build a model in the most abstract sense- above and beyond any drawing.  I really want Vault to be the place where my silly putty is kept and drawings be just places to pull info out.
I REALLY REALLY DO.
I just need to see it with my own eyes and slowly dig my way out of CAD mismanagement purgatory, which is what i think a lot of us live in.
Dinosaur
« Reply #25 on: September 04, 2006, 03:30:31 PM »
. . .  slowly dig my way out of CAD mismanagement purgatory, which is what i think a lot of us live in . . .
Why did you not at least stop by to say hello when you were in my office . . . no, on second thought purgatory would have been the floor above mine . . .
Cannon
« Reply #26 on: September 04, 2006, 03:31:16 PM »
And I admit that I got to cheat. I went directly from being that user in hell trying o slog through it every day, being the one to test it and get it wrong, to being the Consultant that just gets to walk in and trash everything in the name of efficiency. There are still some battles I put off (layouts, JP?) but they're in my mind, and I'll eventually take them on.
No one pays a consultant to hear how they're doing everything right. It would be a short career if I couldn't find something to fix, right? So why not fix it all?
So, I did get to skip the dance that Jason, Nick, and Dana all do so well, the AE support shuffle. I never had to deal with someone who had bitten off more than they could chew, was working all weekend, and then called me for support.
So, to make a long story short, if you want the ideal, sometimes pie in the sky, plan, you can look for my answers, if you want the right answers right now, look to them. The cool part is that we're all sharing knowledge and making it better for everyone I hope.
Jason Hickey
« Reply #27 on: September 04, 2006, 07:06:12 PM »
That support shuffle is what makes the job so fun.   :roll:
One thing that makes the Nick, Dana, James, and Jason show so great is that we all have our own ideas and ways that we think are best.   The great thing about Civil 3D is that there's an unlimited number of ways to skin a cat.   What I tend to do is take my initial idea, Nick's idea, Dana's idea, and James' idea and combine all of them into one MEGA idea, which we then try to document  ;-)   In most instances, the final workflow is greater than the sum of its parts.
OK, now who wants to sing a rousing round of Kumbaya?    ;-)
