Author Topic: (C3D '09)Arc length between two points  (Read 3579 times)
  • Custom Title
« on: February 05, 2009, 10:20:28 AM »
Looking at the image below; Is there a way to measure that "Arc Length" in C3D '09? I couldn't find a way to do it so I wrote an app in AutoLISP but I'm still curious.
Re: (C3D '09)Arc length between two points
« Reply #1 on: February 05, 2009, 10:21:55 AM »
one could label it...
Dimension it....
or....should it be a single arc segment the Inquiry Tool would work...
I would probably stick a label on it....
« Last Edit: February 05, 2009, 10:27:56 AM by mjfarrell »
  • Custom Title
« Reply #2 on: February 05, 2009, 10:26:23 AM »
Dimension it....
or....
Really! Well pretend I'm from Missouri. LOL
  • Custom Title
« Reply #3 on: February 05, 2009, 10:27:25 AM »
It's not a single segment.
sinc
« Reply #4 on: February 05, 2009, 10:27:45 AM »
Most of the time, I have arcs already labeled.
But occasionally I've drawn a "temporary" arc segment over the area I want to ID, and ID the arc segment to get the arc length.  Then I delete the "temporary" arc.
I suppose I should add this ability to the Sincpac-C3D.  Maybe a PTARC command, to go along with the PTINV and PTANG commands...
« Reply #5 on: February 05, 2009, 10:31:35 AM »
Dimension it....
or....
for the good people in Missouri
« Last Edit: February 05, 2009, 10:36:29 AM by mjfarrell »
  • Custom Title
« Reply #6 on: February 05, 2009, 10:31:43 AM »
I don't use something like this often but it sure saves time when I do.
  • Custom Title
« Reply #7 on: February 05, 2009, 10:35:07 AM »
Dimension it....
or....
Are the two curves single segments? If so I'd like to see how you did that. :)
« Reply #8 on: February 05, 2009, 10:37:54 AM »
labels in C3D, when do you want your Prime training?
and the other is a lame dimension.....
  • Custom Title
« Reply #9 on: February 05, 2009, 10:45:09 AM »
Well, as they say, "you learn something new every day"!
Command: _dimarc
Select arc or polyline arc segment:
Specify arc length dimension location, or [Mtext/Text/Angle/[color=red]Partial[/color]]: p ( not exactly what I wanted but ... )
Specify first point for arc length dimension:
Specify second point for arc length dimension:
The autolisp app I wrote is attached.
« Reply #10 on: February 05, 2009, 10:50:20 AM »
True
  • Custom Title
« Reply #11 on: February 05, 2009, 10:57:48 AM »
I'd like to start tomorrow but my employer doesn't. *sigh* Training is a major problem here, our budget is very slim at the moment. But yeah, I'd like to take some of your courses Michael.
« Reply #12 on: February 05, 2009, 11:06:58 AM »
Slim, I can work with  :wink:
NONE would be a big problem.   :roll:
I trust they want more productivity and profits though don't they?
There is a group somewhere in America right now, coordinating with their local technical college to bring me to them to keep the cost down.
