Author Topic: How can I insert a variable into this statement  (Read 1178 times)
sln8458
  • CMS Intellicad 9.0/10.0
« on: January 29, 2021, 03:55:36 AM »
Following on from my previous posts.
I am trying to create a 3D solid of a concentric reducer, taking the dimensions from a text file.
sample from the text file:
("24x16" "Con-Red_SCH_10_24_16-3D" "Con-Red.sld" 508.00 00.00 406.00 00.00 06.35 610.00 06.35 63.00 597.30 393.30)
  (setq    N1 (nth 3 SIZE_DIMS))
  (set_tile "n1" (rtos N1 2 2))
How can I insert a local variable into this statement ?
     (setq spt3 (strcat "0" "," "0" "," "200"))
I want to change the value 200 to the variable ERLENGTH.
I have tried:
(setq spt3 (strcat "0" "," "0" "," erlength))
The following code works with the value 200 in place. [ "200" ]
(defun DRAW_ER ( / spt1 spt2 ENT1 ENT2 ENT3 ENT4 ENT5 ENT6 EROD1 ERID1 EROD2 ERID2 ERLENGTH )
(setq EROD1 N6)
(setq ERID1 N9).
(setq EROD2 N3)
(setq ERID2 N10)
(setq ERLENGTH N1)
 (if (and (setq spt1 (getpoint "\nSpecify Start point of Reducer"))
          (setq spt2 (getpoint "\nSpecify Direction of Reducer"))
     ) ;end of AND
    (command "ucs" "ZA" spt1 spt2)
(command "circle" "0,0,0" "d" erod1) ;take OD from dim file
(setq ENT1 (entlast))
(command "circle" "0,0,0" "d" erid1) ;take ID from dim file
(setq ENT2 (entlast))
(command "circle" spt3 "d" erod2) ;take OD from dim file
(setq ENT3 (entlast))
(command "circle" spt3 "d" erid2) ;take ID from dim file
(setq ENT4 (entlast))
; ; setvar LOFTNORMALS 1  set this to 4
(setvar "LOFTNORMALS" 4) ; this works on command line
(command "loft" ENT1 "" ENT3 "" "")
(setq ENT5 (entlast))
(command "_loft" ENT2 "" ENT4 "" "")
(setq ENT6 (entlast))
  (command "subtract" ENT5 "" ENT6 "")
    (command "ucs" "_P")
(setvar "LOFTNORMALS" 1)
    ) ;_ end of progn
   )  ;_ end of IF
) ;end DRAW_ER
Any pointers or reading material where I can find my solution would be appreciated
Steve
There is no such  thing as a 'silly question' to those who do not know!
Re: How can I insert a variable into this statement
« Reply #1 on: January 29, 2021, 01:32:51 PM »
(setq ERLENGTH (rtos n1))
sln8458
« Reply #2 on: January 30, 2021, 05:55:14 AM »
Thanks Jeff
