Author Topic: How to check if coordinates are equal ?  (Read 9770 times)
Re: How to check if coordinates are equal ?
« Reply #15 on: May 13, 2012, 12:19:29 PM »
Or simply;
  1. (defun _RemoveWithFuzz ( item lst fuzz )
  2.     (vl-remove-if '(lambda ( x ) (equal item x fuzz)) lst)
  3. )
  4.
VovKa
  • Ukraine
« Reply #16 on: May 13, 2012, 02:43:23 PM »
when dealing with coordinates, i suggest checking distances between them
(equal (distance p1 p2) 0 fuzz)i think it's more correct
« Reply #17 on: May 13, 2012, 02:49:12 PM »
that is a good idea
irneb
« Reply #18 on: May 14, 2012, 05:10:36 AM »
In that same vein, you could then get rid of the equal function itself. All you need to figure is if the distance between the points is smaller than the fuzz:
(< (distance p1 p2) fuzz)
dgorsman
« Reply #19 on: May 14, 2012, 05:01:47 PM »
Depending on the means used to calculate the distance, it could start throwing errors if the coordinates are far enough away from the WCS origin (we get this quite often with models in mm).  For example, if the numbers need to be squared in the distance calculation.  Progressive checking (e.g. first X, then Y, then Z) may be of some benefit, since if the first value is too far off the rest of the values are irrelevant, same with the second.  Changes it from multiple square/root operations to a comparison of reals.
There may also be some other concerns - doesn't (distance...) use some current dimension style variables for precision?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
gile
  • Marseille, France
« Reply #20 on: May 27, 2012, 07:03:38 AM »
The minFuzz routine returns the minimum fuzz usable with equal according to the point position within the significant digits of a floating point number.
Code - Lisp: [Select]
  1. (defun minFuzz (n)
  2.   (if (zerop n)
  3.     1e-14
  4.     (expt 10. (- (fix (/ (log (abs n)) (log 10))) 14))
  5.   )
  6. )
(minFuzz 1.234567890123456) returns 1.0e-014
(minFuzz 1234567.890123456) returns 1.0e-008
To compare points whith the greatest minFuzz of the 2 points coordinates:
  1. (defun equalPoints (p1 p2)
  2.   (equal p1 p2 (apply 'max (mapcar 'minFuzz (append p1 p2))))
  3. )
irneb
« Reply #21 on: May 27, 2012, 07:25:12 AM »
That's a very good idea. One thing I'd do though: Calculate the minFuzz only on the coordinate vale which has the largest absolute value:
  2.   (equal p1 p2 (minFuzz (apply 'max (mapcar 'abs (append p1 p2))))))
Don't know if this might be faster, but to me it looks more logical.
irneb
« Reply #22 on: May 27, 2012, 07:35:18 AM »
It's the first I've heard of that, aren't you thinking of the rtos function? You have a point about the squaring though, I think the distance function uses the Pythagorean theorem. So it squares all values and then square roots them, thus it might produce larger floating point errors than expected.
On the other hand, comparing xyz values creates a fuzz box in a cube form, while comparing distances fuzzes a sphere. So the same fuzz in xyz might make for a larger distance between two points if they fall in opposite corners of the cube.
irneb
« Reply #23 on: May 27, 2012, 08:08:24 AM »
  2.   (if (zerop n)
  3.     1e-14
  5.   )
  6. )
To get the min Fuzz even smaller, you might want to change the 14 decimal points to 52 binary points. Seeing as the double precision uses 53 bits for the significand, and 11 for the exponent. But that's just splitting hairs ... literally  :lmao: .
