Author Topic: How to get point inner rectangular  (Read 3453 times)
Adesu
« on: November 07, 2006, 01:16:22 AM »
Hi Alls,
I got problem to get point inner rectangular,that point have Z value,if I use my code, variable "ss" would get result nil,any one have idea?,thanks
(defun c:test ()
  (setq p1 '(0.0 0.0 0.0))
  (setq p2 '(1.0 0.5 0.0))
  (setq ss (ssget "_wp" (list p1 p2)))
Serge J. Gianolla
Re: How to get point inner rectangular
« Reply #1 on: November 07, 2006, 02:56:17 AM »
Have not looked at your ZIP file. I do not understand when you say points have a Z value, yet in your example Z=0!
If point p2 is opp. corner of rectangle, you cannot use WP to select! And if you are after WP then you need more points in your list. You cannot have a polygon with one gon/edge/side.
Adesu
« Reply #2 on: November 07, 2006, 03:41:06 AM »
Hi Serge,
Very sorry last post without zip file,it file have memory more than 10 kb,I'm still to attempting post here with others way.
I hope you patient to wait my zip post here.
CarlB
« Reply #3 on: November 07, 2006, 03:45:03 AM »
I think Serge has it.  You probably should use "_W" or "_C" instead of "_WP".
Adesu
« Reply #4 on: November 07, 2006, 04:14:28 AM »
Hi CarlB,
Here my code to erase object point inner rectangular
(defun cl3 (lst / b)                          ; by Adesu
  (setq b (member (cadddr lst) lst))
  (list (list (car lst)(cadr lst)(caddr lst))
(list (car b)(cadr b)(caddr b))
(member (cadddr b) b))
(defun c:test (/ ang cnt ep p1 p2 p3 p4 sp ss sse ssl ssn ssx)
  (setq ss (car (entsel "\nSelect a line"))) ; select 3dpoly line
  (setq vevo (vlax-ename->vla-object ss))
  (setq cor (vlax-get vevo 'Coordinates))  ; (9.14339 7.64805 1.5 24.0489 22.0432 2.5)
  (setq len (length cor))                  ; 6
  (setq div (/ len 3))                     ; 2
    (= div 2)
      (setq lst (cl3 cor))                  ; ((9.14339 7.64805 1.5) (24.0489 22.0432 2.5) nil)
      (setq sp (nth 0 lst))                 ; (9.14339 7.64805 1.5)
      (setq ep (nth 1 lst))                 ; (24.0489 22.0432 2.5)
      (setq ang (angle sp ep))              ; 0.767982
      (setq p1 (polar sp (+ (* pi 0.5) ang) 2.5))
      (setq p2 (polar sp (+ (* pi 1.5) ang) 2.5))
      (setq p3 (polar ep (+ (* pi 1.5) ang) 2.5))
      (setq p4 (polar ep (+ (* pi 0.5) ang) 2.5))
      (setq ssx (ssget "_w"  p1 p3 '((0 . "point"))))
      (setq ssl (sslength ssx))
      (setq cnt 0)
      (repeat
ssl
(setq ssn (ssname ssx cnt))
(command "_erase" ssn "")
(setq cnt (1+ cnt))
)                            ; repeat
      )                              ; progn
    )                                ; if
  )                              ; defun
« Reply #5 on: November 07, 2006, 07:41:36 AM »
Maybe this?
;;  get pline vrtex list
(defun get_pline_cor (elst)
  (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) elst))
(defun c:test (/ ang cnt ep p1 p2 p3 p4 sp ent sse ssl ssn ssx)
  (prompt "\nSelect a closed LWpolyline")
  (if (setq ss (ssget ":E:S" '((0 . "LWPOLYLINE")(-4 . "&")(70 . 1))))
      (setq ent (ssname ss 0))
      (setq cor (get_pline_cor (entget ent)))
      (setq cor (append cor (list(car cor))))
      (setq ssx (ssget "_cp" cor '((0 . "point"))))
      (command "_erase" ssx "")
    ) ; progn
  )  ; if
Adesu
« Reply #6 on: November 07, 2006, 07:00:18 PM »
Hi CAB,
Your code got trouble,look this below
_$  (setq ss (ssget ":E:S" '((0 . "LWPOLYLINE")(-4 . "&")(70 . 1))))
nil
_$ (setq ent (ssname ss 0))
; error: bad argument type: lselsetp nil
_$
« Reply #7 on: November 07, 2006, 07:42:30 PM »
No, his code does not have trouble :-)
You do !
You missed the (if .... statement
If the ss is not nil then do everything in the progn ...
you try to (setq ent .. when ss is obviously nil
« Reply #8 on: November 07, 2006, 07:54:48 PM »
 :wink:
Adesu
« Reply #9 on: November 08, 2006, 12:42:45 AM »
Hi Kerry and CAB,
I'm still analysising my code to solve that problem,look at this.
the problem still in variable "ssx"
_$ (defun get_pline_cor (elst)
GET_PLINE_COR
_$ (prompt "\nSelect a closed LWpolyline")
    ) ; progn
  )  ; if
nil
_$
<Selection set: 91>
<Entity name: 6b062000>
((-66.7092 46.6143) (72.8231 46.6143) (72.8231 -9.22905) (-66.7092 -9.22905))
((-66.7092 46.6143) (72.8231 46.6143) (72.8231 -9.22905) (-66.7092 -9.22905) (-66.7092 46.6143))
nil
_$ (setq ssx (ssget "_cp" cor '((0 . "point"))))
nil
_$
Adesu
« Reply #10 on: November 08, 2006, 12:56:11 AM »
Hi CAB,
That right your code is perfect,I just tested again.
thanks a lot for your help.
