Code Red => AutoLISP (Vanilla / Visual) => Topic started by: MeasureUp on December 06, 2010, 10:55:19 PM
How to modify an individual dimension object?
For example, I know I can change the "dimaunit" value by selecting a dimension & using the "dimoverride".
But I can't find the "dimaunit" value when selecting the dimension object picked.
The only onething found from the HELP in "HEADER Section Group Codes" (HEADER section) is:
$DIMAUNIT
Group Code = 70
Angle format for angular dimensions:
0 = Decimal degrees;
1 = Degrees/minutes/seconds;
2 = Gradians; 3 = Radians;
4 = Surveyor's units
But there is another group code of "70" with different meaning in "Common Dimension Group Codes" in ENTITIES section.
Thanks in advance.
Try: vla-get-AngleFormat
(defun c:test(/ ent obj)
(and (setq ent (car (entsel "\nPick a dimension for angle format.")))
(setq obj (vlax-ename->vla-object ent))
(or (vlax-property-available-p obj 'AngleFormat)
(prompt "\nThis is not a angle dimension."))
(princ "\nThe angle Format is ")
(princ (vla-get-AngleFormat obj))
It works. Thanks CAB.
More questions,
1) there is no way to get it by using DXF code directly, is this right?
2) And where to get the entire vla- functions reference? (It is not found in the HELP).
Dim overrides are stored in extended entity data:
(entget (car (entsel)) '("*"))
You probably can change them "directly", but it won't be very easy.
The attached may help in that respect.
I should have realized where this was going. 8-)
http://www.theswamp.org/index.php?topic=3313.msg40725#msg40725
Here is a very old lisp that looks at the dimension xdata:
;;; DimPrec.lsp
;;; By Charles Alan Butler 04/27/2003
;;; This routine will flag all dims that have dimension text
;;; over ridden or have a precision greater less than 1/32 .
;;; One or more of the following symbols are placed over the dimension
;;; Symbols
;;; CHECK = Dimensions that have a precision >= 1/32
;;; S = Dimensions that are STYLE dependent for precision
;;; Circle/ = Dimensions with precision less than 1/32 (0.00000)
;;; SquareX = Dimensions that have Text Overrides
;;; Diamond+ = Dimensions that are rounded off & precision is ok
;;; The symbols used are placed on Layer "DefPoints"
;;; and sized according to DIMTXT size variable,
;;; or the Text Style of the DIM if it's size > 0
;;; Limitations :
;;; not designed to work in paper space.
;;; USCS World plan view only
;;; Revision 04/12/04
;;; Correction for ACAD2000, blocks are created on layer 0 now
;;; Dims selected are visible in space you are working
;;; not All dims & frozen as before
;;; Streamlined code
;;; Revision 12/17/05
;;; Added the Rounded Off flagging of dimensions that are within
;;; the precision of the style
http://www.theswamp.org/index.php?topic=8098.0
Removed code and added link...
This another in this thread. http://www.theswamp.org/index.php?topic=24561.0
Haven't located any great examples yet.
OK here is one using DXF codes.
http://www.theswamp.org/index.php?topic=10317.0
