Author Topic: Disable permanently the input-field for help near title  (Read 7728 times)
rkmcswain
Re: Disable permanently the input-field for help near title
« Reply #15 on: June 28, 2016, 10:03:54 AM »
Quote from: mjfarrell
Why indeed, if the answer is both complete and unambiguous?
Depends on the definition of "complete". I know what you meant, but plenty of people out there in the CAD world do not, hence the post I made with the screenshots and "more" details. Such as:
+ Exactly where to find the DWORD
+ How to change it
+ Noted that AutoCAD should be closed, which really does not matter, but if someone does the REGEDIT with AutoCAD open, they will not see the results until after a restart.
+ Also provided some simple lisp code for those who may want to use that.
So, yeah, it's MORE information.
Further if a user is so new that they can't figure out REGEDIT, it could be a sign that they should NOT be in the registry editing anything.
Those same users probably shouldn't be using CAD applications either, but the fact is they are.
The real travesty here is that Autodesk doesn't provide a GUI tool for disabling this and that users have to restore to registry editing.
Peter2
« Reply #16 on: June 28, 2016, 11:04:56 AM »
...that Autodesk doesn't provide a GUI tool for disabling this and that users have to restore to registry editing.
But Manusoft does ... in the meantime a found a tool for it:
http://www.manusoft.com/software/freebies/misc.html
Peter
BricsCAD V23
« Reply #17 on: June 28, 2016, 01:33:23 PM »
IgnoreList.Add("AssHat");
Atook
  • AKA Tim
« Reply #18 on: June 28, 2016, 02:00:12 PM »
I concur. Didn't we have this feature installed?
Can we have it back please?
« Reply #19 on: June 28, 2016, 02:14:50 PM »
Profile > Account Settings > Modify Profile > Buddies/Ignore List > Edit Ignore List
« Reply #20 on: June 28, 2016, 02:23:10 PM »
so many swampers viewing their profiles right now :2funny:
Atook
  • AKA Tim
« Reply #21 on: June 28, 2016, 02:24:38 PM »
Thanks MP, I guess I forgot where it was. :)
« Reply #22 on: June 28, 2016, 02:28:18 PM »
no, just two
« Reply #23 on: June 28, 2016, 02:36:06 PM »
Issue:
You are working in a secure location and you do not want the system to connect to the internet. You would like to disable the Communication Center in AutoCAD.
Solution:
You will need to open Regedit and search for InfoCenterOn.  You will need to change the value from 1 to 0.
Most users here can not run Regedit due to policy restrictions. :-/
« Last Edit: June 28, 2016, 02:56:19 PM by Mark »
« Reply #24 on: June 28, 2016, 02:45:45 PM »
Issue:
Solution:
Most users here can not run Regedit do to policy restrictions. :-/
For those no amount of information would help them then, would it?
However it would then serve as a guide for IT (often ignorant of the care and feeding of autocad themselves) to follow.
Matt__W
  • I like my water diluted.
« Reply #25 on: June 28, 2016, 02:49:15 PM »
Can't... look.... away....
Autodesk Expert Elite
« Reply #26 on: June 28, 2016, 02:49:23 PM »
Might want to take your link to that school out of your signature
The O’Reilly School of Technology is now closed.
Unless you like serving up dead links.
« Reply #27 on: June 28, 2016, 02:58:14 PM »
Issue:
Solution:
knowledge is a power.
« Reply #28 on: June 28, 2016, 03:08:11 PM »
Issue:
Solution:
more or less potential power, unless they have admin rights, right?
