Author Topic: Start AutoCAD and show splash screen  (Read 3376 times)
dann.boy.001
« on: August 24, 2010, 06:55:08 AM »
Hello!
I want to run autocad and show my splash screen and hide autocads
splash.
What is the best way to to this, maybe someone want to share code.
Best regards,
Danijel
huiz
  • Certified Prof C3D
Re: Start AutoCAD and show splash screen
« Reply #1 on: August 24, 2010, 09:31:58 AM »
You can show your splash screen and then start AutoCAD with the parameter /nologo.
« Reply #2 on: August 24, 2010, 02:30:45 PM »
You can also build your program as a stand alone executable that:
a) starts AutoCAD with the window hidden (or find the open session)
b) display your splash screen
c) load your .net application into AutoCAD
d) show the AutoCAD window
although the /nologo option works too ...
dann.boy.001
« Reply #3 on: August 26, 2010, 06:46:34 AM »
Thank you!!!
I will try this.
Best regards,
Danijel
n.yuan
« Reply #4 on: August 26, 2010, 10:33:47 AM »
You can also show a form as spash screen in your IExtensionApplication.Initialze().
The reason one want to show Splash screen is when there is a major custom add-ins being loaded into AutoCAD. Sometimes, the add-in suite need to do some initialization, which may take a bit time. Showing splash screen can be used as an indication that the custon apps are loading.
Of course, with this way the splash screen can only be shown when the DLL that has IExtensionApplication implemented is loaded. That is, if your custom app is loaded on Acad startup (by demanding load or by using acad.lsp...), or the splash screen is shown when the DLL is manually loaded (NETLOAD, commandline, menu/toolbar click...). IMO, to associate the splash screen with the initializing/loading your custom apps makes a bit more sense.
dann.boy.001
« Reply #5 on: December 13, 2010, 04:52:58 AM »
Please,
do you have some example how to pass parametar /nologo when run
AutoCAD application?
Thank you
Danijel
vegbruiser
« Reply #6 on: December 13, 2010, 06:48:57 AM »
This is how I do it when using AutoCAD Mechanical 2011:
(See attached)
You can probably just remove the "/p <<VANILLA>>" part.
Also, the "/b ..\..\bin\debug\start.scr" text is used if you want AutoCAD to open a specific drawing and start a command - netload for instance. (You have to put the necessary details in the start.scr file)
