Author Topic: object align adaptation  (Read 1007 times)
mbrandt5
« on: January 04, 2017, 01:06:37 PM »
I'm interested in having this code adapted to do a few things...if anyone with more knowledge is interested in helping me i'd really appreciate it.
http://www.lee-mac.com/objectalign.html
The changes I would like to have occur is to have the objects snap to a line in an xref.
Hugo
Re: object align adaptation
« Reply #1 on: January 05, 2017, 04:18:46 AM »
The user is then prompted to select a curve object (this may be a Line, Polyline, Arc, Circle, Ellipse, XLine, Spline etc.) to which the selection of objects are to be aligned. The selected curve may be a primary object, or an object nested with a Block or XRef, nested to any level.
Lee writes that it also works on X-Ref and that goes also.
Ok snap does not go sorry must read more.
Lee schreibt das es auch auf X-Ref funktioniert und das geht auch.
« Last Edit: January 05, 2017, 05:06:31 AM by Hugo »
