Hi folks,
I am attempting to make a label which i will manually add to an alignment curve (will not be part of a label set). My objective is to label the distance to the next PVI in conjunction with the profile slope.
I have included an Alignment reference text component to the label, for DIST to NEXT PVI. And another Profile reference text component for INSTANTANEOUS Grade.
When i make a label, I am prompted to select an alignment, then a profile. The Instantaneous grade works fine but the DIST to NEXT PVI is blank. I have also tried to get this value to show up in a Surface label without success.
Why would I not be getting this value show up?
