Author Topic: How to set hpassoc to 0 if loginname = A A and/or B B or else 1  (Read 2159 times)
MvdP
« on: December 13, 2007, 11:37:31 AM »
I have a couple of coworkers and they all prefer a different settings.( F.i hpassoc 0 or 1)
Is it possible  to set hpassoc to 0 if username is A A or B B and else set to 1 in an mnl file.?
I have this for now but it ain't working.
(cond ( = getvar loginname "firstname lastname" (setvar "hpassoc" 1)))
David Hall
  • Automatic Duh Generator
Re: How to set hpassoc to 0 if loginname = A A and/or B B or else 1
« Reply #1 on: December 13, 2007, 11:40:07 AM »
i think you need an IF statement
« Reply #2 on: December 13, 2007, 11:48:41 AM »
  (setq name (strcase (getvar 'logginame) T))
  (cond ((= name "username")
;;do stuff
((= name "username2")
;;do stuff
« Last Edit: December 13, 2007, 11:52:06 AM by ronjonp »
« Reply #3 on: December 13, 2007, 11:56:31 AM »
I think you're over engineering the solution (as a former boss used to say). Consider ...
(setvar "hpassoc"
        (member
            (strcase (getvar "loginname"))
           '("BARNEY" "FRED" "BAMBAM")
        0
        1 ;; the default setting
« Reply #4 on: December 13, 2007, 12:45:37 PM »
(setvar "hpassoc"
        (member
        0
Now why didn't I think of that... :-D Thanks for idea MP
« Reply #5 on: December 13, 2007, 12:53:41 PM »
My pleasure Ron. :)
MvdP
« Reply #6 on: December 13, 2007, 01:28:53 PM »
Thank you very much.
« Reply #7 on: December 13, 2007, 09:43:25 PM »
You're welcome MvdP.
