Author Topic: osnap icons  (Read 7336 times)
krampaul82
osnap icons
« on: January 17, 2011, 04:29:16 PM »
Gentlemen
For some reason my object snap icons have dissapeared! Is there some kind of setting that needs to be re-set? :oops:
StykFacE
Re: osnap icons
« Reply #1 on: January 17, 2011, 04:36:29 PM »
Are you talking about the icons on a Toolbar or Status bar, or are you talking about the actual Snap Icons within the drawing model? You can toggle the OSnap feature by hitting the F3 key. See if that yields the results you're after.
Matt__W
  • I like my water diluted.
Re: osnap icons
« Reply #2 on: January 17, 2011, 04:47:18 PM »
Maybe this??
Autodesk Expert Elite
Matt__W
Re: osnap icons
« Reply #3 on: January 17, 2011, 04:48:11 PM »
Or are we talking about the toolbar....??
krampaul82
Re: osnap icons
« Reply #4 on: January 17, 2011, 04:53:31 PM »
The model space.
krampaul82
Re: osnap icons
« Reply #5 on: January 17, 2011, 04:55:22 PM »
The cursor icon to indicate which snap will occur (ex. a perpendicular line snp)
Nibster
Re: osnap icons
« Reply #6 on: January 17, 2011, 05:02:45 PM »
check your Autosnap settings in the DRAFTING tab of your OPTIONS
krampaul82
Re: osnap icons
« Reply #7 on: January 18, 2011, 08:53:55 AM »
The object snap is working it is just that the cursor icon has dissapeared like an endpoint snap or a perp snap etc...
M-dub
Re: osnap icons
« Reply #8 on: January 18, 2011, 08:57:12 AM »
This was going to be my suggestion as well.
Re: osnap icons
« Reply #9 on: January 18, 2011, 09:03:26 AM »
if you tap the tab key
you should be shown not only the Snap being applied it will also indicate what object the snap is being applied to
Chris
Re: osnap icons
« Reply #10 on: January 18, 2011, 09:21:49 AM »
Is it possible that the options have become deselected?
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
krampaul82
Re: osnap icons
« Reply #11 on: January 18, 2011, 09:50:03 AM »
That was it! my marker box was un checked thank you all!
Re: osnap icons
« Reply #12 on: January 18, 2011, 09:57:34 AM »
Is CAD working to your liking right now?
If YES, go back into OPTIONS and save, then export your current GOOD Profile to someplace safe.
Then when things go awry, you can IMPORT that profile you just saved, set it current, and move on.
CCDesigner
Re: osnap icons
« Reply #13 on: February 28, 2011, 05:47:35 PM »
This is an excellent tip to follow on a regular basis. I've made it part of my backup routine. I don't know how many times my profile has become corrupted and I'm left sitting there for 30-45 minutes figuring out and resetting my profile...and it's never 100% again. :realmad: :-)
Jeff Benson
Re: osnap icons
« Reply #14 on: May 05, 2011, 07:44:19 AM »
i also tried this tip and this is really very nice tip :mrgreen:
http://dashquid.com
http://fatlossprofessional.co.uk
http://fatlossprofessional.co.uk/how-to-lose-weight-fast/
http://mobilehelper.co.uk
http://securetrip.co.uk
http://whichpetcover.com
http://youtube.com
http://wikipedia.org
http://twitter.com
http://amazon.com
« Last Edit: October 04, 2012, 04:11:41 AM by Jeff Benson »
