Author Topic: Xref Layers  (Read 4732 times)
Fabricio28
Xref Layers
« on: April 27, 2015, 11:23:45 AM »
Hi guys,
I don't know what is wrong with xref layers.
What I have to do to fix it?
Regards
Rob...
Re: Xref Layers
« Reply #1 on: April 27, 2015, 11:27:34 AM »
That notification is for new XREF layers. It's just to let you know that the properties might need to be looked at. If you are happy with the settings, select all the layers in that filter, right click, and select "Reconcile Layer".
CAD Tech
ChrisCarlson
Re: Xref Layers
« Reply #2 on: April 27, 2015, 11:28:12 AM »
Just right click and select reconcile. It's basically making you confirm it will plot how you want when your plot style is applied to the xrefs.
Re: Xref Layers
« Reply #3 on: April 27, 2015, 12:19:00 PM »
Probably one of the single most annoying 'features' autodesk ever introduced.
Rob...
Re: Xref Layers
« Reply #4 on: April 27, 2015, 12:26:29 PM »
Really? Just because you don't see a value in it, doesn't mean that there isn't.
CAD Tech
Krushert
  • FREE BEER Tomorrow!!
Re: Xref Layers
« Reply #5 on: April 27, 2015, 12:29:57 PM »
Agreed
First, If there is a value, I have yet to find it.  Second, I am entitled to my "opinion", I hope.
Re: Xref Layers
« Reply #6 on: April 27, 2015, 12:37:13 PM »
You have the OPTION to turn it on or off...
Re: Xref Layers
« Reply #7 on: April 27, 2015, 12:43:34 PM »
Proves the 'value' of it that it can be turned off.
Krushert
Re: Xref Layers
« Reply #8 on: April 27, 2015, 12:47:35 PM »
Ohh I have it turned OFF!
You can bet your tail wacker six ways to Sunday that I have it turned off.
But honestly, to each their own on how they want set up and run Their AutoCAD.
Rob...
Re: Xref Layers
« Reply #9 on: April 27, 2015, 12:48:46 PM »
You live in a closed world, don't you. There is a value to it, maybe not to you, but there is.
CAD Tech
ChrisCarlson
Re: Xref Layers
« Reply #10 on: April 27, 2015, 12:53:30 PM »
Actually the value is indeed quite important if you deal with xrefs not generated on your companies layer / color standard.
Re: Xref Layers
« Reply #11 on: April 27, 2015, 12:53:57 PM »
Just because you don't like it doesn't mean someone else won't find it useful. Since when are options in software an indicator of usefulness ?
Re: Xref Layers
« Reply #12 on: April 27, 2015, 12:55:33 PM »
Yaah there is a  value to being alerted that one just attached an XREF or inserted a BLOCK into one's
file and maybe, just maybe there might be some new layerss that might not plot the way you want them too.....
really...
and then when you plot, those new layers STILL don't plot the way you wanted them too...because, hell you really didn't
KNOW how you wanted them to plot or that the idiot that made the block or gave you the XREF had his #$it all BYOBJECT
or some other whacked ass settings....
Yeah LAYEREVAL really saved me some time.....now didn't it...NO
Re: Xref Layers
« Reply #13 on: April 27, 2015, 12:57:13 PM »
and you wont know that right away....or that the imbecile didn't really follow any standard...colors by object
linetypes and lineweights by object...LAYEREVAL is NOT going to solve that
Rob...
Re: Xref Layers
« Reply #14 on: April 27, 2015, 12:59:47 PM »
So, because you have a situation that it doesn't work in, means that it doesn't work at all?
CAD Tech
Re: Xref Layers
« Reply #15 on: April 27, 2015, 01:03:10 PM »
In MOST cases it detracts more than it adds to my particular workflows.
SO for me NO, no it really doesn't 'work' or do anything I find of value.
dgorsman
Re: Xref Layers
« Reply #16 on: April 27, 2015, 01:08:58 PM »
I'm not using it, even so I can see that some would have a use for it.
There does need to be a "pot stirring" smiley.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Rob...
Re: Xref Layers
« Reply #17 on: April 27, 2015, 01:09:16 PM »
And that is AutoDesks fault, why?
CAD Tech
Rob...
Re: Xref Layers
« Reply #18 on: April 27, 2015, 01:09:46 PM »
There should be a troll killing button, too.
CAD Tech
Fabricio28
Re: Xref Layers
« Reply #19 on: April 27, 2015, 01:33:36 PM »
Hi guys!
Thank you very much for the quickly and useful replay.
Worked fine for me.
Regards
Re: Xref Layers
« Reply #20 on: April 27, 2015, 02:58:20 PM »
And how would it NOT kill you also?   :2funny:
