Author Topic: copy "altitude" value into "elevation" v  (Read 3409 times)
dom
« on: August 03, 2004, 04:57:52 AM »
Hi all,
I need help in reading the "altitude" value in property's of a polyline.
I then need to write that, into the "elevation" value, in the properties of
that same polyline.
Thanks in advance.
/Dom
Dommy2Hotty
« Reply #1 on: August 03, 2004, 08:37:29 AM »
woah...another Dominic...
« Reply #2 on: August 03, 2004, 08:49:20 AM »
I don't see an "altitude" property in a pline.  :?
dom
« Reply #3 on: August 03, 2004, 10:43:32 AM »
Yeah, there is another Dominic!
I believe that I have 2D polylines.  I select one, and then right click it,
then select properties.  In the last section "OD:VMEL_CONTOUR", the first
element is "ALTITUDE".
I want to copy this value from there, and change the "Elevation" in the
"Geometry" section of the properties, to be the same.
I have been able to get the X and Y values from the "Geometry" section
using:
(setq thelist (vlax-get-property theobj 'coordinates))
But have been unable to get the Altitude.
Does anyone know how to get this value?
regards
/Dom
« Reply #4 on: August 03, 2004, 10:59:37 AM »
Are you using a 3rd party app? Or are you getting these dwg's from someone who is?
dom
« Reply #5 on: August 03, 2004, 11:08:30 AM »
I'm using Autodesk Land Desktop 2005.
Don't know what the people who originaly made it were using.
« Reply #6 on: August 03, 2004, 11:26:31 AM »
Quote from: dom
so am I and I can't find any reference to "ALTITUDE" any where. What happens if you explode one?
