Author Topic: Can't find 50 Blocks  (Read 5446 times)
Re: Can't find 50 Blocks
« Reply #15 on: October 29, 2015, 03:50:42 PM »
Wblock the drawing over itself.
Interesting...as stated above a simple wblock still left two anonymous blocks.
craigr
« Reply #16 on: October 29, 2015, 03:54:29 PM »
I am still left with the question of what causes this?
Though it has been a few years ago, it was I that created these very simple blocks. I did nothing fancy. Could it be the adding of the wipeout at a later date to the original block?
The block just seems too simple to create this issue. But, obviously something did.
« Reply #17 on: October 29, 2015, 03:59:49 PM »
Not here  ;)
_$
"*MODEL_SPACE"
"AcDbBlockReference"
"*PAPER_SPACE"
"Camera1"
"AcDbHatch"
"AcDbLine"
"AcDbLine"
"AcDbLine"
"AcDbPolyline"
"AcDbLine"
"AcDbLine"
"AcDbLine"
"AcDbLine"
; 1 form loaded from #<editor "C:/Users/ScoobyMcScooberson/Desktop/foo.lsp">
_$
« Last Edit: October 29, 2015, 04:03:09 PM by ronjonp »
« Reply #18 on: October 29, 2015, 04:25:56 PM »
Scooby snacks for you then
« Reply #19 on: October 29, 2015, 05:13:40 PM »
« Reply #20 on: October 29, 2015, 05:39:11 PM »
Reason in your case is Dgn linestyles, they fixed it in 2015 or 2016 where it will purged orphaned data.
I ran code that stripped the beginning * and you see what they are and look like symbols inside of a linetype
« Reply #21 on: October 29, 2015, 05:49:39 PM »
Here's what the VLIDE says
